Gday all... been loving my S3... already rolled up over 2000km on it and it seems to be well run in now
Had a couple of issues and can't be assed to take it back to the unhelpful dealers unless I need to... maybe someone here can help?
Power windows... Sometimes after putting the windows up on auto-up, it goes up and then comes down about 15cm. After this, auto-up/down both stop working. This also happened in my brother's MkV Golf GTI. I've found the way to "reset" the motor, by taking the window all the way up, then holding up for around 5 sec... This works and auto-up/down start working again for a while... and then the problem repeats some time later. Is there any kind of permanent fix?
4th gear... Most of the time putting the car in 4th gear causes the gear shifter to vibrate a bit when accelerating or engine braking at pretty much all revs, but I tend to notice it most between 2000-3000rpm. Power seems to be all there... None of the other gears do this, they are rock solid in gear. Very rarely when crawling through traffic 4th gear is as solid as the rest, but most of the time with what I call normal driving, it sends vibrations up the lever. Whats going on? Anything I should be concerned about?
Bose... Bose is a standard option here in Australia... but somehow they managed to *not* fit it. It's happened to a couple of guys here, esp those with satnav. Got in contact with Audi Australia and they have sent me a $1900 cheque (cost of Bose is a 3-door A3) :icon_thumright:
Think thats it... It'd be great if anyone could shed light on my two issues.
Cheers guys
Cheers guys
