because the 140 comes with welded on bent trims, the 170 has welded on straight trims but I guess that those will slide over without removing the factory trim. I would guess that they would fit the 140 but you will need to remove the standard trims first, email the seller to see if they can tell you if they are welded on clamp on with screws.
