bacardi said:now.........
driving backwards
New tyres on front or on rear?
Are they still classed as FWD, or do they become RWD?
driving backwards
sleep envy said:you <-------------stick--------------->point
4 new tyres - use car = worn rears, half worn fronts
replace rear tyres = half worn fronts, new rears
use car again = worn fronts, worn rears
replace all four, etc, etc
ok, there will be a point that the fronts will have more tread depth but there's nothing you can do about
Teejay said:er, no.
If you have 4 new tyres and for arguments sake lets say the fronts take 20,000 miles to wear down 8mm. The rears take 10,000 miles to wear down 8mm and are replaced twice in the same period the fronts are changed once.
After 1000 miles, the fronts have worn 0.4 mm, the rears have worn 0.8mm. So the fronts have more tread depth.
This will be the case right up until the rears are changed. Then the rears will be slowly playing catch up with the fronts.
Time you checked your logic
phantom said:Ive changed my tyres over ( new-ish Mitchelin pilot sport ) to the rear they were on the front!
The other day i took the car out for a blast ( not driving crazy ) i went over a crest that drops down and turns left, my fronts started spinning and the car started too understeer , but the rears brought me back in too line, it just showed me how vital the rears are on this car!
What with reading this thread , and watching the videos , and the above episode ive put me good tyres on the rear!
Granted you would be unlucky for your rear to flip out like in the vid's , but it could all the same , better to be safe than sory!
p
marriedblonde said:But you dont know how th ecar would have behaved if you had kept the new ones on the front, perhaps you wouldn't have even been in that situation?
J.
