Thanks so far to all those who have helped.
The steering wheel ECU I had was 8P0 953 549 I replaced with the F version.
The coding in (16 Steering Wheel) I used was 0011142 (auto, no multifunction, paddles, on board computer, cruise + wiper)
I have tried all the Ross-Tech coding with no joy.
I have now changed the steering wheel ECU back to my original, then carried out the procedures on ross tech, worked when stiching engine off in between (THANKS GTI JAZZ BLUE)
BUT now I dont have cruise (not that it worked with the new ECU)
All the dash errors have gone, I presume I dont have cruise working because I need the F version ECU.
I have been doing a bit more reseach
http://www.audi-sport.net/vb/showthread.php?t=22590
moogie said:
If you need to buy a new electronics unit, make sure that you buy one that is compatible with your steering wheel slip ring. I spent quite a few hours trying to figure out why my new module didn't work properly, until it was found that it wasn't compatible..
As far as I know, there are two different slip rings:
1K0 959 653 A
1K0 959 653 D
If your steering wheel module (use vag-com to check) is 1K0 959 549 E or F, then you have the D slip ring. If the module is 1K0 959 549 or 1K0 959 549 A, then you have the A slip ring.
The correct replacement modules with cruise functionality are:
8P0 953 549 A (compatible with slip ring 1K0 959 653 A)
8P0 953 549 C, D or F (compatible with slip ring 1K0 959 653 D)
Hope this helps.
Getting a bit complicated now, I have 1K0 959 653 A (slip ring) so I presume I need a new slip ring version D.
Can anyone confirm this?
Do I need to do any coding in the engine section, if so what?
