JMB RetrofitsChris Nott
Thread: OE Mudflaps
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    OE Mudflaps
    What's you opinion on these?
    I'm interested in both the asthetical and practical side of things and whether they are worth the Ł30 a pair (once vat and postage have been added) vagparts.com charge?
    Ron
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    Boydie
    are you getting your audisport 10% discount as well?
    In my opinion they are there for a practical reason hence why i kept mine
    unfortunately the standard ones on the front no longer fit due to me fitting votex side skirts
    543
    How do I claim the discount? Didn't know about that!
    Do they work though? I think they look a little too short to effictively catch the spray.
    Rob
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    I'm probably going to fit them but get them painted first.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    rob1210's Avatar
    Nov 2007
    Mudway, Kent
    124
    does fitting involve any drilling?
    Car History
    "57" Audi A3 2.0tdi 170 S-Line S-Tronic, Phantom Black
    "56" VW Golf 2.0tdi Sport
    "55" Audi A4 2.0t S-Line Quattro
    "51" BMW 330d Sport
    treblesykes's Avatar
    Nov 2004
    york
    688
    to fit the front ones you can leave the wheel on and just steer to full lock to get access, no drilling just remove some screws from in the arch,(torx ones if I remember) the mudflaps attach using theses same screws simple!
    Rear ones you have to remove wheels to get to the same torx screws, that bit is also simple but then you drill one hole at each side into the valance , This hole can be drilled thru the attached mudflap so you are sure in the right place. Then into the drilled hole you push a plastic sleeve, a drawing pin shaped pin then pushes into this sleeve expanding it so it grips tight.
    I only ever got this pin in 3/4 of the way as its very tight but its been ok in 3 years. You cant tap it with anything as the valance bounces. The mud flap fully covers the drilled hole.
