JMB RetrofitsSky Insurance
Results 1 to 12 of 12
    S3RVA
    Jul 2007
    49
    S3 8P - Mechanical Noise from rear hub!
    Just on my way to B&Q earlier and I'd just commented on the brakes sqeaking abit. Anyway next thing is I hear a load of mechanical scraping like metal on metal.
    Was tempted to get the RAC out just in case but drove it home none the less. Looked at it on the drive and its defo comin from the back left hub/ calipers - cant figure it out further as the weathers attrocious here atm.
    Anyone experienced anything like this? Ive just short of hitting 9k miles and am nearly due for the service?
    I'll keep you updated as soon as I find out.
    Scotland
    154
    Had a similar experience, turned out that a stone had managed to get itself wedged between the brake disk and the backplate. Sounded terrible and highly embarrassing in a new car!
    Jan 2005
    cambs uk
    1,139
    me too, had a stone wedge itself in there, very odd noise (Thought it was another wheel bearing )
    S3RVA
    Jul 2007
    49
    good stuff I can handle a stone lol
    cheers guys will see what it is in the morning hopefully
    S3RVA
    Jul 2007
    49
    if it is a stone idve looked a proper numpty callin the RAC out... lmao
    lucianobacheta's Avatar
    Aug 2007
    19
    same here, a loud whining noise.. turned out to be a nearside rear wheel bearing, have it booked in now, dealer says its safe to drive!!
    sure, until the wheel falls off!
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    I had a stone stuck in mine. Just do some high-speed reversing, that freed it up on mine and was fine ever since......
    987 Boxster 2.7 (05) - Current
    A3 2.0T Quattro S-Line (55) - gone
    S3 Quattro (02) - gone
    murray
    Nov 2006
    Surrey
    17
    Noise from rera hub
    I had the stone problem too. It sounded terrible and we were in the process of moving house so called the RAC as I had no time to deal with it. The solution the RAC chap used was to take the wheelbrace and firmly press on the lower edge of the rear disc cover plate (which projects below the disc). A very small stone fell out!! Slightly embarassing as it took longer to do the paperwork than it did to cure the problem.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Also had the stone problem years ago on my VR6 Golf. However a friend of mine has just had his rear pads replaced on his 57 plate S3 due to a squeeking problem under warranty!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    S3RVA
    Jul 2007
    49
    Yup was a stone between the disk and the guard plate - ground it down to a shiny mirror too.
    All is now well - thanks for the replies folks
    Scotland
    154
    Glad to hear that's all it was, now go out and enjoy the car
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Did it not knack your disc a bit where it had been rubbing against?
