Chris NottSky Insurance
Results 1 to 7 of 7
    Leeds
    36
    Unhappy Arrghh!! Anyone had locking wheel-nut drilled off before?!
    I think one of the rear wheel bearings has gone on my recently purchased A3, and I decided first of all take the noisy-side rear wheel off and replace it with the space saver just to discount a buckled wheel... however it turns out I dont have the locking wheel-nut bit!!!!
    Has anyone been in this situation before? What does it cost to get them drilled off? Or can I go to Audi and get them to find out what nut remover it needs and buy one?
    Any help appreciated!
    2004 A3 2.0 TDi Sport - Silver - Remapped
    Aug 2007
    41
    I think there are a limited number of combinations and Audi should be able to provide you with a replacement.
    Paul
    ______________________________
    A3 2.0 TFSI Sportback SE S-tronic Ice Silver
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I had an issue this weekend with knackering my locking wheel nut adaptor when swapping my wheels. The dealer had a box of about 20 different locking adaptors. I used one of theirs which matched the number on mine.
    But now I need to buy another matching locking wheel nut adaptor. My dealer said he will order a new one for me.
    Leeds
    36
    Luckily found mine lodged under one of the seats
    Thanks for the pointers anyhow!
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by s8craig
    I'm a bit concerned about there only being 20 different locknuts. What would my comeback be should my locknutted wheels be stolen by an enterprising thief who has the full set of locknut adaptors?
    I had assumed that there was some sort of database where the dealer could look up which locknut your car has should you need to order a replacement. Something similar to the car key system.
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    970
    Quote Originally Posted by MarcQuinlivan
    This been my reason for not using Audi locking bolts, I use an aftermarket set.
    Its the same with Mercedes, Last year I was removing an alloy on a Mercedes at work and broke the locking wheel key. So a trip to Mercedes and the workshop chappie came out with this case of locking wheel keys (think there were 20-25 ish) tried each key until he got the right one. Then ordered me a new one
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    Brookie-S3's Avatar
    Wakefield
    67
    i work for mondial, we look after all the major manufacters, bmw , mini , merc,
    i carry bmw, new x old, mini , landrover master set of locking wheel nut keys, and the same is theres only about 20 for each make.
    my advice is a set of mcgaurd, these are the best on the market
