Results 1 to 14 of 14
    Correct tyres for 18" rims on an A3?
    Hello,
    This is my first post since buying my first audi so sorry if the question is stupid.
    Just before xmas I got my A3 sportback 1.8T SLine. I got it with the 18" rims option but found that there was much rubbing of the tyres on the inside of the bodywork.
    Of course I took the car back and Audi said they fitted rims with the wrong offset. Fair enough, mistakes happen. So today I collected my car again with the 18" rims with the correct offset but I notice that the tyres do not match what the Audi spec brouchre says. The booklet says that they should be 225/40 tyres for the 18" rims but Audi have fitted 235/40 tyres...
    Should I be concerned about this difference?
    Ta!!
    S3IZZO
    No I wouldn't be concerned...will offer more rim protection
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    235 40 18s could cause rubbing issues as their side profile is 4mm higher than the 225s, and they will screw your speedo up as they are a larger rolling diameter.
    Not sure why they would fit the wrong tyres, other than they are Muppets.
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Aside from being the wrong width, and therefore height, do they have 'XL' or 'EXTRA LOAD' written on the sidewall?
    If they don't, that's another reason to get the dealer to change them for the proper ones.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Sep 2006
    383
    Guess they put on the tyres from the wheels that had the incorrect offset,make them put the correct size on
    Oct 2006
    246
    Quote Originally Posted by mikep
    Isn't the '40' number referring to the height of the sidewall. Surely a 225 40 will have the same sidewall height as a 235 40 tyre (unless I've been wrong all these years about the 2nd number referring to the sidewall height)?
    Anyway, I have 18's fitted and have 225 40 ZR18 Extra Load tyres fitted with no issues at all.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by coupe-se
    No, the profile is a percentage of the width.
    So a 225/40 tyre is 225mm wide, with a 90mm sideall.
    A 235/40 tyre is 235mm wide, with a 94mm sidewall.
    Oct 2006
    246
    Quote Originally Posted by bowfer
    Cheers mate, learnt something today. So the the 40 is actually saying 40% of the width then.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    thanks for your advice guys, looks like i'm taking it back to audi - again
    ta!
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    yes it's a ratio
    the sped rating is generally worthless but the higher the number is the better the tyre performs before it deforms.
    i think STD for 18" alloys would be 88 and XL is 92 and above
    225/40/18 -92 Y is your ideal tyre
    There is a table somewhere that gives you and a max weight for the code.
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Hello and welcome Black Sline to the site.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Sep 2006
    52
    Audi probably fitted some wheels off an A4 S-Line to your car. They all run 235s or 245s.
    I replaced my 225 PZero with 235/40 goodyears. Ride was better / more supple. Done 12k on them now no problems.
    Took the car for a long drive today with just me and the wife, I didn't notice any problems with the 235/40 tyres audi fitted.
    But this evening we went out with two other people in the back the the rears rubbed quite often going around corners.
    I want the 18" rims cause they look great, is rubbing with a full load in the car just something I should put up with. I thought it seemed reasonable to think that if audi offer 18" rims as an option they should fit in all conditions.
    well, i'll call audi on monday and see what they say...
    can anyone tell me if they should be able to fit 225/40s to a rim that is 8 inches wide?
