Volks AutosChris Nott
Results 1 to 12 of 12
    I cant spell !
    Jun 2007
    North West
    434
    Removing A Pillar cover ?
    I'm trying to hard wire my road angel in - I know how to wire it in to the fuse box so it switched - but how do you get the A pillar cover off & is it safe to take the cover off as the car has the blanket airgbags ?
    Richard
    Jan 2007
    Hampshire
    1,155
    You can just grab it and pull it off but if you are only wanting to route a wire then I wouldnt even bother. Just push the wire in behind the trim using something like a credit card.
    A6 3.0 TDI.
    I cant spell !
    Jun 2007
    North West
    434
    Cheers - Think will have to remove the whole A Pillar cover as trying to get the RA lead to the bottom right of the windscreen !
    Richard
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Yes - Just pull the A-pillar trim off a little way. Then you need to slide the trim up toward the roof to completely remove it.
    Be careful if you are running cables at you need to ensure that they are well out of the way of the curtain airbag.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Dec 2006
    Ireland
    2,538
    Dave R (otherwise known as H5DJR) might be able to give to the workshop guide for removing this.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Not quite sure why you'd need a diagram? All the info is above.
    The Damned
    Apr 2007
    South Yorkshire
    344
    This should help you
    I cant spell !
    Jun 2007
    North West
    434
    Ah now that is good !!! very impressed !!
    Where did you get those pics from ?
    Richard
    The diagrams are from the ElsaWin electronic workshop manual that is used by all Audi dealers.
    Here is a link to the full pages...
    http://homepage.ntlworld.com/h5djr/e...veA-pillar.pdf
    Dave R (h5djr)
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by h5djr
    How does one gain access to ElsaWin Dave?
    Jan 2007
    Hampshire
    1,155
    Ebay!
    A6 3.0 TDI.
    I have sent you a PM with details.
    Dave R (h5djr)
