AH FabricationsSky Insurance
Results 1 to 10 of 10
    Oct 2003
    up north...
    767
    ARB and suspension choices recommendations
    im looking to upgrade my 2.0tdi SE handling without going hard or silly - its a road car not a racer but i want less understeer without being s-line or s3 harsh.
    ARB kit to reduce understeer
    neuspeed rear only? Eibach F+R kit? H&R F+R kit?
    lowering to add negative camber
    Eibach lowering springs -30mm
    ?other not too hard options
    dampers at some point
    Bilstein? were perfect for 8L s3 but for the 8P?
    Koni FSD? seem to be good
    alternatively is a cheap coilover kit going to be harder/better/worse than the above - i dont need adjustability i need good compliant fit and forget road car settings, i was considering:
    FK = koni?
    Weitec = KW
    any recommendations?
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Talking
    I'd get the Weitec . Same as me Dunk . I'm gettin KW V2s and the H&R anti-roll bar kit . I can't find any tie bar kits for the 2.0 tdi (140)..
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Oct 2003
    up north...
    767
    thanks,
    you say you are getting kw v2 but recommend weitec - how come?
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Cuz I noticed not many people on this forum are gonna pay £850 for suspension!!!!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Weitec's and H&R ARBs! Great setup!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Dec 2007
    52
    Why not just get the car's geometry set up properly instead of replacing parts that by default will need to have the geometry done anyway? It would be a lot cheaper. A full geo (non-corner weighted) shouldn't cost more than perhaps 130 by a proper motorsport company. Don't confuse this with a kwik Fit tracking check.
    Saying that I'm not sure how adjustable the A3 suspension is, but toe, camber, caster could all be set up on standard suspension on previous cars and 3rd party suspension was only needed to lower the car and give it a low centre of gravity and allow it to be fully corner weighted (not more camber as that could be done already).
    The other thing to remeber is that a front engines, front/four wheel drive car is always going to have an understeer tendancy unless you know how to drive around this an provoke oversteer. Perhaps some performance driving lessons would be a good idea? I know several guys that I would recommend very highly indeed. One of them is based at the Top Gear track which you would get to yourself for an hour or so.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Thanks for your advice rich. Know most of things already though.
    Oct 2003
    up north...
    767
    unfortunately the front camber is fixed at almost nothing and with a heavy engined car this is going to make dialling out the understeer very difficult
    negative camber is going to involve either new lower arms modified for negative camber or lowering the car.
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    Oct 2003
    up north...
    767
    are the weitecs going to be harder than a standard SE? and if so, will they be as hard as the s-line stuff that everyone seems to complain about?
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Get fully adjustable damping coilovers then you can set it up how u like..
