Monster MotorsportChris Nott
Results 1 to 9 of 9
Thread: LED Side Lights
    Feb 2007
    52
    LED Side Lights
    hi Guys,
    Hopefully someone can help me. I bought some Ignition LED Sidelights a few days ago. Installed them no problem worked for like 20 minutes and then i got a Warnign on my DIS saying bulb had gone! Went to check the light and it was out!
    Any way round this? Should i buy a resistor? I saw on HIDs4u.co.uk you can buy a pair of resistors for a 5 but b4 i do that wanted to check if there was a work around?
    Cheers!
    P9LAD
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    You'll need resistors to get them working properly. Have a search through the forum as pretty certain this has been discussed before.
    Jon
    Now A3 less......
    RGBArgee
    Quote Originally Posted by p9lad
    hi Guys,
    Cheers!
    P9LAD
    What's the point of LED sidelights? I am genuinely intrigued. I know Audi are introducing on new models but why bother retro fitting, everyone knows they are not standard fit?
    Jan 2007
    Hampshire
    1,155
    I guess he means changing the bulb for an LED one as opposed to fitting LED lights light the A5/S6 etc?
    Some people like the look of the LED bulb, a bit closer to the light color of the Xenom headlight.
    Not my cup of tea I must admit but each to their own!
    BTW a resistor will defintley be required to turn off the blown bulb indicator in the DIS.
    A6 3.0 TDI.
    RGBArgee
    Quote Originally Posted by Issac Hunt
    Ta for clarification... but IMHO what's the point?
    R
    Jan 2007
    Hampshire
    1,155
    Quote Originally Posted by RGBArgee
    R
    Havent a clue but like I say some folk like it as it gives a closer colour to that of Xenons. I couldnt be arsed to fit them to mine but each to their own I guess.
    If we were all the same the world would be a grim place!
    A6 3.0 TDI.
    RGBArgee
    Agreed we would all be brain washed into buying BMW's with PP's !!
    Black Standard Quick Audis are best IMHO!
    Feb 2007
    52
    hi guys, well basically i noticed the light is a lot brighter then the normal sidelights i already have. also like previous members have said it is more of a Xenon look. A friend of mine who does all car electricals audio, alarms and what not has got soem resitors so will fit them in on wednesday!
    On a side note just fitted Ignition HID Kit to the car! Works brilliantly! No alarms, Wiper motor has not blown up yet and the light is brilliant!
    Dec 2006
    Ireland
    2,538
    You can say that again! (Oh wait, you do - a lot!)
