Chris NottAH Fabrications
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 141
  1. #41
    L60N
    Quote Originally Posted by phantom View Post
    The Phantom on the rollers
    Heres the plot , they couldn't do a flywheel/clutch reading running in 4WD.
    My car is std , so i'm very happy with the results
    p
    Im reading from this the car put out 250hp-ish & 280lb Torque. So where are you getting that your car is putting out 280 standard?
    Or am I totally missing somthing?
  3. #42
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
  4. #43
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,196
    Awesome cannot measure flywheel figures in 4wd and the 8P's wouldn't run in 2wd (the 8L's will)
    As a comparison my 3.2 ran 200bhp ish atw
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
  5. #44
    On Boost
    Manchester
    1,756
    Thats at the wheels mate, the only true way of testing the power of the car on a dyno, flywheel or clutch power are estimated readings.
    TBH i'v hit a brick wall in converting it to flywheel power , as i don't know if transmission losses have been taken into account, and if they haven't how much are they on a Haldex/Quattro which is mostly 2wd , but still has 4wd running gear!
    p
  6. #45
    sat1983's Avatar
    Feb 2007
    Leeds
    708
    Phantom that pic of yours is my new background. Great looking motor!
    Ex 2006 A3 2.0 TDI owner
    2010 Polo GTI 6R
  7. #46
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,196
    If mines running spot on, which I've no reason to doubt looking at previous 3.2 plots at awesome, then I've got roughly 50bhp in losses as an A3 3.2 is booked at 247 fhp. The only difference between my running gear and an S3 is the dsg box.
    What was surprising on the day was the difference in standard and remapped S3's. Peak bhp wasn't anywhere near as big as suggested over a standard car. This doesn't mean the car doesn't perform much better than standard as it's the change in area under the curve that makes the difference. But when you are paying for a map under the impression that you're going to get almost a 50/70bhp increase when you're actually only getting 15/20 it would make a lot of people think twice.
    Previous
    2008 Red S3
  8. #47
    L60N
    Ah, thanks for clearing that up. I was like
  9. #48
    On Boost
    Manchester
    1,756
    So for pub talk reasons what is the flywheel BHP on mine and mitch78 cars?
    p
  10. #49
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,196
    p
    Just think off any number you like TBH because that's what it is, a Guess!. Going off yesterdays figures, I'd say you would be looking at somewhere over 280bhp
    But then you've got the debate about the accuracy of the rollers etc. RR days are only any good for comparing different cars on the same day, same rollers, especially when the figures are repeatable between identical cars.
    Previous
    2008 Red S3
  11. #50
    Sep 2006
    383
    Quote Originally Posted by mitch78 View Post
    I think it's because none of the mapped S3s got more than about 10-15 bhp more than mine or Phantom's. Having said that, they did gain about 25-30 lbft of torque at the lower end of the range.
    I think it's more a matter of mine and Phantom's producing quite a lot more than they should. And I know people will think "well he would say that" but as the mapped cars were showing so little difference compared to ours, (and there was a guy from APR Australia in Awesome) they flashed an APR map onto mine and gave it another run to see what figures it got, and it was pretty much identical to all the other mapped S3s. Just a shame that they had to take it straight back off again.
    Most usefull test of the day before and after dyno,same car,same day,just different map
  12. #51
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    Before I had my S3 MTM remapped, I had dyno's done and my car was running standard at 282bhp, well over the standard figures Audi had given..
  13. #52
    Sep 2006
    383
    Quote Originally Posted by klauster View Post
    I assume that was based on guessing the drivetrain loss (most peoples guess on audi haldex setup seems to be 30-40 bhp loss) so your dyno plot was around 240bhp at the wheels?
    Did you have a dyno done after the remap?
  14. #53
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    I had before and after plots, I dont know if they were estimated or not, but remember Kim at QSTuning saying that the stock bhp was higher than it should be.
  15. #54
    JohnS3's Avatar
    Oct 2004
    3,021
    p
    I wouldn't get to hung up on BHP figures, it's the torque figure that's important and the higher the better.
  16. #55
    On Boost
    Manchester
    1,756
    So if the pub talk guess is 280+bhp how does that affect the torque? does that get rounded down too?
    p
  17. #56
    JohnS3's Avatar
    Oct 2004
    3,021
    If you measurements were taken at the wheels then the readings at the flywheel would be higher or vice versa.
    You can use vagcom to take readings from the onboard sensors, this may give you a better idea of the flywheel to wheel losses. When I did some plots on my standard car I had 268 HP and 272 lbft or torque.
    My torque comment was aimed at comparing maps, but my fingers didn't get around to typing it!
  18. #57
    On Boost
    Manchester
    1,756
    So the torque on my plot upto 288lbft is right?
    p
  19. #58
    Sep 2006
    383
    As I understand it there are many variables when using rolling roads
    Ambient temp
    Stationary temps (my cooper s needed a big fan blowing into the front to keep the intercooler temps down or the ecu would retard the ignition)
    Wheel weight/size/tyre pressures
    Actual drivetrain loss (will vary between the same type of cars)
    Roller calibration
    I suggest that Phantom takes his engine out ,put it on a rig and gets clutch bhp output,then puts it back in the car and dyno it again,difference will be drivetrain loss
  20. #59
    S3-N's Avatar
    Feb 2008
    263
    The data logging done with vag com before my remap showed 275bhp standard. Seems like they are definitely more than the quoted stock 262bhp
    Phantom Black B7 S4 + Milltek
  21. #60
    On Boost
    Manchester
    1,756
    I'm not hung up on flywheel figure , it's just i couldn't even TRY to explain it too the wife or friends who are asking what the car ran!
    p
  22. #61
    S3-N's Avatar
    Feb 2008
    263
    So what did the GIAC Hammer map produce???
  23. #62
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
  24. #63
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Quote Originally Posted by S3-Nick View Post
    This rings true with the TTS coming out as having 272bhp as standard....
    Looks like the Audi marketing department have been "playing" again giving the S3 lower figures on paper to what it really has.
    Anyone remember back when the first TT came out it had more than the S3 (8L) even with the same engine then all of a sudden they had the same power after a while....
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
  25. #64
    S3-N's Avatar
    Feb 2008
    263
    about 258bhp and 300lbft
    If that's the hammer I wonder what the 310bhp map actually produces
  26. #65
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Any 2.0T's run their cars?
  27. #66
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,196
    No mate only 4 S3's and 1 3.2 in the 8P's
    Previous
    2008 Red S3
  28. #67
    S3IZZO
    The revo map on my car produced slightly higher BHP than the "Hammer" map but slightly lower Torque figures.
    The real difference is the way the car drives though after a remap, it certainly feels much much more than the indicated 15-20bhp difference.
  29. #68
    On Boost
    Manchester
    1,756
    ^^^^^^Hiya mate, spin took me out for a drive ( he offerd me the wheel , but i said no " it's not my car " )
    It did feel faster , and more eager when he floored it, but to be honest it wasn't night and day compared to my car when i floor it.
    Me and spin were talking about trying another rolling road , to make sure these figures are correct , if they are i don't think i'll bother with a remap untill my warrety runs out!
    leon - aka Phantom
  30. #69
    Oli.'s Avatar
    551
    Some interesting results there. Like has been said even though the figure arent overly different - +20BHP +40ft lb - Its the driveability that makes all the difference.
    And on the subject of RR's, they all seem to produce different figures, so actual figures can be taken with a pich of salt - but comparing mapped to stock is very important - are there any actual prinouts/ploting graphs comparing this?
    www.bmvs-camperhire.co.uk VW California hire and sales
  31. #70
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
  32. #71
    S3IZZO
    leon - aka Phantom
    Hi Leon,
    I did some testing myself on the drive back (turning Revo on and off with the Revo select device) and this IMO confirmed it was worth every penny paid for it.
    To be honest I was expecting a little more from the GIAC map in terms of numbers on the rollers. I would be happy to attend a different RR with you guys to compare
    Good to meet you all
    Jordan
  33. #72
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
  34. #73
    On Boost
    Manchester
    1,756
    Are you gonna scan your plot up Lee?
    Do you know the results of the other S3 , the red one? Louay? i had gone by that point.
    p
  35. #74
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    I think you would need to drive the car yourself to really feel the difference thats why I offered you the wheel, I've ran mine back on standard map over the weekend and there is no doubt The mapped car is far, far quicker, in fact very much night and day when pressing on. Don't get hung up on the figures from saturday - I'm not convinced there even worth discussion because clearly something was very wrong with the figures achieved by all 8P S3's on the day. I enjoyed the day and meeting all the Guys but am disappointed to say I don't think we got value for money on the day, RR days are always a little hit and miss figures wise and I was obviously surprised by the results but the lack of continuity is very suspicious, if you Guys with the standard cars want to go on believing that 2 reputable companies like GIAC and Revo can only offer a 15/20 bhp advantage over standard then thats your perogative but seriously..................
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
  36. #75
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Agreed. A mapped S3 should feel night and day. A mapped 225bhp TT feels night and day so should a new S3...
  37. #76
    On Boost
    Manchester
    1,756
    ^^^^^^^I hear what your saying spin , and thats why i said i would/will like to go on another rolling road with you to get a second opinion on these figures.
    I was all set to get the GIAC remap put on my car after you blew us all away, but it didn't turn out like that , so if the runs were correct ( still willing to go somewhere else with you ) then i have to way up the options.
    Thanks mate
    p
  38. #77
    Vtec Abuser's Avatar
    Jul 2007
    Lincoln
    305
    Really interested to see what another set of rollers say guys. As I am changing my mind day to day on whether to go GIAC Hammer or go with Revo again when I get my Ed30..
  39. #78
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Aren't the most accurate rolling roads the ones where they machine goes straight to the hub?
  40. #79
    S3IZZO
    Phantom,
    Figures aside, i'd urge you to actually drive a car with switchable settings to get a feel for it yourself. (You're welcome for a go in mine)
    Infact who cares about figures - anyone up for a 1/4 Mile session at Santa Pod?
  41. #80
    Jul 2007
    Lincoln
    305
    Quote Originally Posted by S3IZZO View Post
    Phantom,
    Now that's what i'd like to see...
    I'd be expecting a mapped S3 to run mid 13's @ around 103-4mph mark..
