Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    Kontraband's Avatar
    Dec 2007
    1,998
    marriedblonde, yeah I agree about the charging side of things... that does suck. But the playing, as Im shuffling, is a case of if I dont like the track that much, it FF it. Next track... the botton is a close as if I was pressing the MFSW, (because Im resting my hand on the gear stick!) I hear what your saying tho... was just giving an alternative view to an aux port being crap, for a no cost option it certainly has some worthwhile..
  3. #42
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Quote Originally Posted by bowfer
    Hang on though, are dension i-pod only?
    I've just bought myself a Sony video walkman (NWZA818).
    I didn't think it through....did I....
    Ah ok yes it is. Right in that case the Aux input is going to be spot on for your needs
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
  4. #43
    Dec 2004
    Sunny South Coast
    4,368
    Quote Originally Posted by Kontraband
    Ok for a no cost option I will concede it is better than nothing
    J.
  5. #44
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by marriedblonde
    My own fault, I should have checked.
    I might just bite the bullet and buy an i-pod instead then, as the Dension does appeal.
    The charging bit especially.
    Cheers for all the advice.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
  6. #45
    Dec 2004
    Sunny South Coast
    4,368
    I bought mine off ebay for New 69 including delivery. Fitting is a doddle as it just plugs into the standard cd changer cables.
    J.
  7. #46
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I bought mine off ebay for New 69 including delivery. Fitting is a doddle as it just plugs into the standard cd changer cables. J.
    D3 doesn't have a CD changer, just a single play, I'm sure.
    Does that complicate matters?
  8. #47
    Dec 2004
    Sunny South Coast
    4,368
    Nope not at all, mines the same as standard just the business head unit, it'll have the cables in place where the changer is normally fitted.
    J.
  9. #48
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Bear with me here MB..
    If you go onto dension's website, it suggests that the applicable product for an E90 with the professional system (which my D3 has, I checked) is their 'gateway 500' product.
    When you look at that, it says it supports ipod/aux/USB.
    So doesn't that mean I should be able to use my Sony, via USB??
    See here
  10. #49
    Dec 2004
    Sunny South Coast
    4,368
    They've expanded what you can actually connect throught the dension. So the main use is the ipod but you also have the option of USB pens drives and an Aux input.
    You control it like a normal cd changer. The different CD's 1-6 on the head unit pick different options.
    Select CD 1 - this allows you to move up and down the tracks.
    Select CD 2 - this allows you to choose the play lists. track 1 is all tracks ipod. track 2 is play list 1, track 3 pllaylist 2 etc
    Select CD 3 - this allows you to jump through the albums
    Select CD 4 - this allows you to jump through the artists
    Select CD 5 - Input Source - iPod, Aux
    Select CD 6 - Dension setup
    Does that make sense?
    J.
  11. #50
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Cheers for all this, MB.
    Looks like I can connect my Sony via the gateway 500 USB, provided it uses FAT12, FAT16 or FAT32 file systems.
    Unfortunately, I can't find anything online to tell me if Sony use any of those.
    I've e-mailed dension.
    Be nice if I could use the Sony, seeing as I only bought it 2 weeks ago!
