AH FabricationsEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
  1. #41
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    When you ordering a set then mike?
  3. #42
    Apr 2004
    1,139
    ... so after all these posts someone clarify? I have a standard three spoke sport steering wheel with awful plastic creaky paddles - are we saying that these can be removed from the steering wheel and new ally ones screwed on as a direct replacement (ie no sawing or chopping or gluing required?)
  4. #43
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    Quote Originally Posted by steve184
    Yep that's what I've been told, I've ordered a set today and I should have them by Friday week. I'll let you know how much fun they are to fit and take some pictures.
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
  5. #44
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Thanks Mike!
  6. #45
    Apr 2004
    1,139
    that will be good mike! 'How-to' would be even better! reckon you wil have to take steering wheel off???
  7. #46
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    No need to remove steering wheel. In fact easier if you don't as when it is attached it is at least not rolling around all over the place. You only need access to the back of the wheel to undo screws fixing the air bag
    Already mentioned above but just to clarify.
    1) Disconnect battery. (You don't want the airbag going off do you?)
    2) Remove 2 plastic bungs from rear of steering wheel (turn wheel to get access to them)
    3) Undo 2 screws at back of wheel to release airbag. These screws are captive screws. You don't actually remove them, just undo then untill the airbag is released.
    4) Unplug Airbag and remove completely.
    5) Where the spokes meet the center of the wheel you will see the multifunction switches. These are held in by small lugs that you will need to release with a small screwdriver. This is a bit fiddly. If you don't have MFSW there will still be some blanking plates that are removed in the same way.
    6) Once the multifunction switches are released you will gain access to the inside of the steering wheel spokes.
    7) inside the spokes you will find one screw holding each DSG paddle switch in place.
    8) Remove the screw.
    9) Remove cable from old DSG switch.
    Installation of new paddle is reverse of above.
    Hope that helps.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
  8. #47
    mikep's Avatar
    Jun 2003
    591
    marms, top bloke!!
    Pragmatik ICT
  9. #48
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Indeed he is, marms how am I gonna find out if the aluminium ones fit mine wheel then? People at audi are useless....
  10. #49
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    you could always buy 1 of the plastic paddles from the A3 and 1 from the TT. It will be a waste of money but might work out cheaper than buying the alloy ones.
  11. #50
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Quote Originally Posted by N8KOW
    Well I know you have bought a TT FBMFSW but as you are buying a DSG car then the original wheel will have the black paddles. If these black paddles fit your TT wheel then the part numbers for the aluminum version above will also fit.
    I expect however that they will not as the TT paddles are a different part number.
    Looks like you are going to have to wait for your car to arrive before you will know for sure.
  12. #51
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Thanks marms..
  13. #52
    Apr 2004
    1,139
    so can you just buy these ally paddles from audi as seperate items? For a standard 3-spoke A3 sport steering wheel (2007)?
  14. #53
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Yeh u can, marms has listed the parts no.s check
  15. #54
    mikep's Avatar
    Jun 2003
    591
    My S8 paddles have arrived, I collect them tomorrow. I'll be following marms instuctions and fitting the paddles on Sunday probably depending on the weather. Pictures will follow......
    Pragmatik ICT
  16. #55
    Apr 2004
    1,139
    Good lad.
  17. #56
    The standard black paddles have obviously changed as well since I had my 140 in 2004. The ones on the 140 made a clicky noise ever time you operated them but the ones on my March 2007 170 a silent in operation.
    When I drove the 140 I very rarely used the paddles, perhaps because they were so clicky, but now I find I use them all the time.
    Dave R (h5djr)
  18. #57
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Thanks Dave
  19. #58
    Apr 2004
    1,139
    Quote Originally Posted by h5djr
    Mine must be a 'Monday' car then because my March 2007 paddles are 'awful' in terms of quality - one reason why i don't use them too much
  20. #59
    mikep's Avatar
    Jun 2003
    591
    Here are the paddles....
    Pragmatik ICT
  21. #60
    mikep's Avatar
    Jun 2003
    591
    Now all I have to do is find some time to fit them!
    Pragmatik ICT
  22. #61
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Thanks Mike, they look really nice, I'm definitely getting a set!
  23. #62
    Apr 2004
    1,139
    Are they solid ally? the paddle part? do they fell pretty solid compared with the plastic ones?
  24. #63
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    They felt solid when I was messing around in a lovely £70k S8 at the audi showroom
  25. #64
    mikep's Avatar
    Jun 2003
    591
    No they're plastic with an alloy finish layer on the front.
    Pragmatik ICT
  26. #65
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    lol
  27. #66
    Apr 2004
    1,139
    hmmm - no different from the normal ones then? plastic is plastic whatever colour its painted!
  28. #67
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    The aluminum look and feel nicer imo. Hence why I'll be ordering the TT-S ones when they become available...
  29. #68
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Mine are definitely not painted.
    They have an alloy body with a plastic inlay in the back. I would say they feel a fair bit meatier to use than my original DSG paddles. Come of the above post give the impression that the s8 paddles are tacky, they are not. Having the back plastic also means they are not cold to the touch.
  30. #69
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Don't those pictures shown an alloy face with black platic background ?
  31. #70
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Yes and No. As I see them the paddles are made of aluminium which has been hollowed out to put in the illumination for the +/- and then a black plastic infill. The paddles are definitely more aluminium than they are plastic. Not just an alloy face.
    Steve, I notice you are in Lincolnshire so you are more than welcome to have a look at them, in situ, in my car if you are still unsure.
  32. #71
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    I may take you up on that offer when I'm allowed o spend on the car i'm in stamford, where are you ?
  33. #72
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    I'm north of the wash nearest 'big' place is Lincoln.
    Know what you mean about the spending though. I doubt I could justify the £110 for little paddles. Mine were free and came attached to a rather lovely multi-function steering wheel.
  34. #73
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Mine will cost me £110
  35. #74
    mikep's Avatar
    Jun 2003
    591
    Quote Originally Posted by SteveTDCi
    Yes, they are plastic on the back with an alloy layer on the front, it isn't painted. They weigh almost exactly the same as the std ones.
    Pragmatik ICT
  36. #75
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Either way I know how nice they felt in the S8! I'm getting a set!
  37. #76
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,389
    So did anyone get round to fitting these? I'm thinking of buying a FBMFSW to replace my current non-MF, and i think the silver paddles would look good! Are these on the new S3 DSG?
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
