Chris NottBadger5
Results 1 to 7 of 7
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    to those who have the tyre pressure monitoring system (TPMS) ?
    i just got this done and fitted and i now have my DIS beeping every 10 seconds displaying a message telling me to check my tyre pressures
    this guide was followed: http://oooo-a3.blogspot.com/2006/04/...stem-tpms.html
    at the end it says,
    'First off, the new button only resets the TPMS learned values, after that it needs some driving distance to relearn these values. The learned values are adapted in several steps (speed ranges), each step (range) is devided into 2 thresholds in 2 stages (powered and rolling). You can check this using VAG-COM and read measuring block 031 in your ABS control module...'
    then it gives a bunch of values etc
    this sort of explains the reason behind the warning on my computer but how long will this stay like this? how much driving do i need to do for my car to learn the pressure values? any tips/help
    thanks
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
    Aug 2005
    West London
    850
    If you hold the button in for 10 seconds the car learns the value/pressure at that time. Then if it drops below that you will get the warning. The part about vagcom values is to set up the wheel and tyre sizes which should already be set unless youve swapped wheels.
    If you reset the light does it stay out until youve driven for a while or come straight back on?
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    Quote Originally Posted by Dandle
    when you say the vagcom bit is to set up the values, how would I set up the values if you say it does it automatically or do you mean I have to input them myself via the software?
    I was just told that a few days of natural driving would stop the warnings/beeping
    When you say if I reset the light, do you mean holding the button for 10 seconds like you first said?
    Apologies, I'm just really confused on how this works, thanks so far...
    DID have...
    most extras.....
    NOW have...
    Big 19's
    Jun 2007
    240
    As far as I know you just inflate the tryes to the correct pressures then press and hold the tpms button until you hear a beep.
    After that the car monitors wheel speed and if the average for one wheel changes then you get a warning as the pressur of the tyre has changed.
    I never had any beeps or warning while driving so I'm not sure why you are getting those.
    ____________
    Sprint Blue S3
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    so if i hold the button for 10seconds, it will beep and learn/store the current pressure values?
    i have not done this and was told to leave it beeping and the system will learn the values by itself...
    DID have...
    most extras.....
    NOW have...
    Big 19's
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    Yes, press hand hold will set the pressure value
    RS Focus MP 350
    Porsche 997 Carrera
    S3 Sprint blue
    A3 SLine170TDI
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    i had my tyres put to the correct pressures
    i pressed and held the 'SET' button, there was no beep even if i held it for 25 seconds
    the beeping/warning ceases whilst the button is held but once i release the button, the DIS starts going off again
    i tried this both stationary and whilst moving
    i know the button is working and my car does register it because when plugged into vagcom and i press the button it says 'ACTIVATED' on the software
    help!!!!!?????
    DID have...
    most extras.....
    NOW have...
    Big 19's
