i just got this done and fitted and i now have my DIS beeping every 10 seconds displaying a message telling me to check my tyre pressures
this guide was followed: http://oooo-a3.blogspot.com/2006/04/tire-pressure-monitoring-system-tpms.html
at the end it says,
'First off, the new button only resets the TPMS learned values, after that it needs some driving distance to relearn these values. The learned values are adapted in several steps (speed ranges), each step (range) is devided into 2 thresholds in 2 stages (powered and rolling). You can check this using VAG-COM and read measuring block 031 in your ABS control module...'
then it gives a bunch of values etc
this sort of explains the reason behind the warning on my computer but how long will this stay like this? how much driving do i need to do for my car to learn the pressure values? any tips/help
thanks
at the end it says,
thanks
