EM TuningMonster Motorsport
Results 1 to 18 of 18
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Back doors freezing shut
    What a PAIN!
    Every morning and night, my car becomes a two door.
    Would silicon spray along the rubber sort it, or something?
    Seems to be at the top, where the rubber meets the body.
    Surprised the rubber is still on the door, as I tend to go a bit postal on it...
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Some people (not me) tend to find Vasaline good for their back doors......
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    JohnS3's Avatar
    Oct 2004
    3,021
    It knows it's going to be swopped for a beemer and is doing it on purpose
    Silicone spray sounds like a good idea, give it a try on one door and see if it makes a difference.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Don't suppose a slight spray of WD40 would do it, would it?
    It's all I've got in the garage.
    Either that or Tesco's finest olive oil.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Quote Originally Posted by bowfer
    WD40 might sting a bit...olive oil better (apparently!)
    JohnS3's Avatar
    Oct 2004
    3,021
    You don't want that in your eye!
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Think I'd rather have sticky doors than stinky doors though.
    The smell of WD40 does my head in.
    Does no-one else get this?
    I have to haul at the damned things, it's that bad.
    I'm no 8 stone weakling, but I have to give up sometimes.
    It's like my first wife, she ain't opening.
    I don't get the problem with my Sportback, but that may because it spends the night in my garage.
    But I have got some Silicone spray which I use on the track of my power operated garage door and that works a lot better than oil, grease or WD40. Its called SP-90 from a company called Action Can Ltd. I bought mine at a local builders merchant. It's described on the can as Release / Non-stick Lubricant Spray.
    Dave R (h5djr)
    RGBArgee
    No problems here with our SB.
    Bowfer, I thought you said no one ever went in the back of your car hence you were not concerned about lack of legroom in a D3??? Or have I missed something...
    TT
    RGBArgee
    Quote Originally Posted by JamS3
    Larry Grayson?
    Nov 2007
    83
    Only the back doors? It's not happened this winter yet, but all four doors icing shut is not unusual. A spray of de-icer sorts it out.
    07 2.0TDi (170) SE DSG Sportback.
    Lava Grey (when it's clean!)
    5 spoke 17 inch alloys upgrade
    Reversing sensors
    No smoking pack
    Warranty issues to date:
    New steering rack - 8,000 miles
    Slight coolant loss - 12,000 miles
    New drive shafts and engine mounts - 18,500 miles
    New mechatronic unit for DSG box and replacement ducting for cooling system 19,900 miles
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by Rick Glover
    TT
    Are you getting -4C in Bristol yet?
    You're right, I hardly ever have anyone in the back of my car.
    However, I like to chuck stuff in the back, like my laptop.
    I could use the passenger seat, if it weren't for the annoying 'BING BING BING' anytime you put anything heavier than a magazine on it...
    I have a double garage, but I'd rather the wife's car and my bike were kept nice and dry, than this piece of sh*t...
    RGBArgee
    Cold here too, only -3! I tend to put my Laptop in the boot... but you will be please to hear there is no bing bing on the new A3 passenger seat! Come on now I think it's only the DSG (Damn silly Gearbox) you don't like!!
    TT (soon) and A3 SB 2.0TQ
    R
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Oh well, in that case I'll cancel the D3 and get another A3.
    kanievsky's Avatar
    Oct 2007
    Stamford
    63
    Use some stuff for door seales like Auto Glym's Vinyl&Rubber care or something with silicone (although as far as I remember BMW's manual says don't use silicone base stuff on rubber) DON'T use WD 40 or deicer on rubber!!!
    When I used to live in Poland I used to do it every 2 weeks in winter time and there was -20 sometimes so I know it's the best solution. Clean the seal and use some door seal stuff on it.
    Jan 2007
    Hampshire
    1,155
    Same for me, it used to drive me nuts everytime I put anything on the passenger seat. Out with VAG-COM and the probelm has gone!
    A6 3.0 TDI.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by Issac Hunt
    I begged the dealer to do it, but they flat refused.
    RGBArgee
    Best piece of news I have heard for weeks. Try Bristol Audi!!
    TT
    R Can't afford the heated seats!!
