Chris NottSky Insurance
Results 1 to 10 of 10
    john_cook's Avatar
    I was the STIG.
    Jun 2006
    Lancashire
    212
    coolant warning light DIS 2.0 TDI (2005)
    Hi everyone,
    can anyone tell me what coolant I need to buy to fill up the reservoir? The light came on about a week ago and is on everytime I start the car. On inspection in the engone bay it is near the minimum level. Do i simply buy some replacement coolant solution and top it up? It had its 2nd service in September and had no such problems then.
    Cooky
    A3 2.0 tdi sport (2005), Xenons, Bose, Leather/Alcantara, 19" replica RS6 alloys, Rieger front bumper/side skirts, Eibach 30mm springs, Caratere Rear Spoiler, Silver wing mirrors, powerflow twin exhaust tips, Alpine iDA-X001 iPod Ready headunit, amp and 1000 watt sub....
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    You MAY have the porous cylinder head problem that a few 2.0tdi owners have reported. (check this forum for previous threads about coolant loss).
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Sep 2006
    383
    Wait untill the engine is cold,undo cap,top up with water(any water will do just for top up) to the max mark and keep an eye on it and see if the light comes back on.If so get it checked out.
    john_cook's Avatar
    I was the STIG.
    Jun 2006
    Lancashire
    212
    Quote Originally Posted by dipstic
    Is that safe?? Maybe I should take it in to audi or call them.
    Cooky
    Jun 2007
    240
    I noticed the other day when topping up washer fluid that my coolant is quite low.
    Car was very cold but the level was around minimum. The warning light hasn't come on and I realise the level goes up when the car is warm but I'm not sure it should be so low.
    Hope I don't have a leak!
    I did spend a couple of hours last weekend at Rally GB with the car idling, maybe this has used some coolant?
    ____________
    Sprint Blue S3
    Sep 2006
    383
    From the manual
    When cold level should be between min and max level
    When hot might be slightly above max mark
    System should not loose coolant if it is visit to Dealers req
    So I would suggest topping it up when cold and seeing if it then loses fluid, if it does take it to the dealer to check
    Jun 2007
    240
    Thanks, I'll take a look today. Normally when hot it was abit above maximum, not sure if it's dropped or just because the car was cold ( and outside temp was near freezing too ).
    I've had it for 3 months so hopefully there is no leak!
    ____________
    Sprint Blue S3
    Mar 2004
    Newcastle, UK
    143
    I had the dreaded "porous cylinder head" problem on my `54 2.0TDi at around 83k miles/38 months.....
    09/04 - 07/08: A3 2.0 TDi Sport DSG: Lava Grey; Xenons.
    kanievsky's Avatar
    Oct 2007
    Stamford
    63
    Quote Originally Posted by Davidb67
    How much did it cost you to have it fixed? Have you had the head replaced?
    alnes's Avatar
    Oct 2007
    cannock staffs
    46
    hi guys i had the head replaced at 60k audi did it under warranty with just a small contribution from my self, total cost was just under 2200 & you get 2years warranty, done approx 1k miles since all fine.
    2.0 tdi S line black on 18s.......
