Badger5AH Fabrications
Results 1 to 18 of 18
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    Question Is Hill Hold, Retro-Fittable to Audi A3??
    Does ayone know if its possible to add the Hill Hold feature to a Audi A3??
    If so, which parts are needed and does it require use of Vag-Com???
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Waste of time mate!
    I have it and it only hold for about 2 seconds and then releases just giving you enough time to find the bite point. Would have been better if it held fully until you move forward.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Don't see the need for it on a manual, but I would class it as an essential with DSG.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Quote Originally Posted by bowfer
    I would tend to disagree with that , I just use the handbrake like you would in a manual until the clutch takes up the drive.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Nov 2007
    83
    I disagree too. Two smarts and two DSG Audis and I've never felt the function to be essential. If you can't swap one foot quickly between two pedals learn left foot braking.
    07 2.0TDi (170) SE DSG Sportback.
    Lava Grey (when it's clean!)
    5 spoke 17 inch alloys upgrade
    Reversing sensors
    No smoking pack
    Warranty issues to date:
    New steering rack - 8,000 miles
    Slight coolant loss - 12,000 miles
    New drive shafts and engine mounts - 18,500 miles
    New mechatronic unit for DSG box and replacement ducting for cooling system 19,900 miles
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by Gti Jazz Blue
    Paul
    But that's assuming you can go.
    If you can't go, you then have the car 'straining' against the handbrake, making the arse go down like a dog taking a dump.
    Or you ignore the handbrake and you get rollback.
    Or you put your left foot on the footbrake, which just confuses the hell out of the car.
    Hill hold would make things a damned sight easier.
    Or just make DSG 'lock up' and not roll back.
    Nov 2007
    83
    My DSG Audi never strains against the handbrake, but I put the car in 'N' after applying the handbrake, just as I would put a manual in neutral if waiting with the handbrake on.
    Reversing sensors
    No smoking pack
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by daveyjp
    If waiting on a hill, in a manual car, you put the car into neutral?
    Never, ever, heard of anyone doing that.
    At lights or traffic jams, fair enough.
    But never heard of anyone doing that whilst waiting at a hill junction.
    Feb 2007
    Hampshire
    1,654
    No I use the foot brake as normal but at the moving off point nip the handbrake up and hold it ready to release as I take my foot off of the foot brake. So effectively just holding it on the hand brake for the delay between taking my foot off the brake and the clutchpack taking the strain.
    Paul
    VCDS HEX-USB+CAN
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    thanks for that, but the question remains, is it retro-fittable???
    persoanlly i dont use the hand brake much when im driving, unless im still for awhile, i tend to keep foot on foot brake, but i just thought the hill hold is ok, them two seconds can be helpfull first thing in the morning. even thought it doesnt eliminate using the foot brake altogether.
    it just seems an easy retrofit, are my assumptions correct?
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    i did some searches about it, but information is very scarce aboout this subject,
    the hill hold doesnt have a button rather its programmed into the ABS ECU????
    any ideas anyone, can anyone confirm this???
    lil_coz's Avatar
    Nov 2007
    1,636
    I think thats the case. No on/off switch but a case of it being part of the system
    mcmasman's Avatar
    Mar 2007
    Norway
    152
    Quote Originally Posted by fesss_84
    Hi, I see where you got the motivation from ...
    Good luck with it!
    2007 Lava grey A3 2.0 140 TDI Quattro Sportsback
    S-line int/ext, cruise, mfsw, aluminum rails, Xenons+, coming-leaving home, light + rain, parking sensors, hill hold, Bluefin, 18" OEM double 7-spokes RS4 alloys
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Correct no on off switch and no way of telling you have it via lights ect,
    Just works off the brake pedal!
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    seeems like the ABS ECU determines if u've got this feature, if anyone has access to Audi part list, the part-no, of ABS Ecu (With Hill Hold) would be great! for Audi A3 2006 2.0 TDi
    The Etka parts list only lists the ABS ECU with the hill-hold fuction ( drive away assistance as it describes it) for 2007 onwards models. The part number for this is 1K0 614 517 AC. Whether this unit would be directly interchangable with your existing unit I've have no idea. I think you would need to seek expert advice from a dealer and the last thing you would want is problems with your braking system.
    Personally I have the standard 'hill-hold' system fiited to my A3 and find it works very well. It called a hand-brake! Engage drive with the hand brake on, release the foot brake, apply light pressure to the throttle and then release the hand-brake. Works perfectly every time.
    Dave R (h5djr)
    The Damned
    Apr 2007
    South Yorkshire
    344
    Quote Originally Posted by h5djr
    Class!
    Dec 2006
    Ireland
    2,538
    Yeah, but perhaps he finds if difficult to do all that with the end of his skirt caught in the door.
