Results 1 to 12 of 12
    Jul 2006
    160
    Haldex Gen II Owners/Advise
    After a couple of hours driving in the wet over the weekend I am seriously thinking about get this mod ASAP.
    I don’t know if you guys have noticed on your cars, but my car goes around corners much better in the wet then in the dry.
    There is noticeably less under steer and I can really notice the rear wheels pushing the car around the corner as the front wheels start to slip.
    I have done a load of research into this and from what I can work out, it will give my car similar characteristics in the dry.
    For all you guys that do have it installed, is this the sort of results I can aspect from this mod or am I way off? Also have you noticed better acceleration due to better traction?
    Audi A3 3.2 Quattro S-Line: Brilliant Black, 18inch Split Rims, DVD SatNav+8GB, BOSE, Light & Rain pack, Lights pack, 2 Tone Nappa Leather, Votex Side Skirts, Superchipped.
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    am also looking very seriously into this mod
    basically, as far as i know it transferrs more power more aggressivly to the rear wheels, if installed with a switch you can choose from race,sport or stock modes
    courtesy of Ben who is able to shed more light on it
    Quote Originally Posted by JaminBen
    The MkIV Golf-platform cars (old A3Q, old S3, MkIV R32, etc.) come with the GenI Haldex controller from the factory. These cars could be upgraded with either the Blue or Orange GenI HPP (Haldex Performance Part).
    The MkV Golf-platform cars (new A3Q, new TT, MkV R32, etc.) come with the GenII Haldex controller from the factory. While similar in design, the two controllers differ in that the latter is tied into the vehicle's CAN network, and therefore uses more signals to determine when and how much torque to apply to the Haldex clutch pack (and thus to what % the rear is tied to the front, i.e. 100% = 50/50 torque distribution). Thanks to this CAN integration, the GenII controller is slightly more proactive than its GenI counterpart.
    MkV cars using the GenII controller can be upgraded with the GenII HPP. This unit has three programs in memory: stock, sport, and race. It can be fitted to the car without a switch, in which case it will be in by-default sport mode. This program applies more torque faster to the Haldex clutch pack than the stock program does, meaning the rear diff is tied to the front more quickly and to a higher degree. This, in turn, makes for less understeer and a more "planted" feeling.
    The GenII HPP is an expensive piece, but it makes for significantly enhanced chassis behaviour. Imo, it is one of the best upgrades one can purchase for a MkV Quattro or 4-Motion car.
    Well, the stock and race modes can only be used if you have a switch installed. If you don't have a switch, then the controller will be in the by-default sport mode which is an intermediary mode.
    Looking at Haldex's documentation, it shows that "sport" applies "more torque faster" than "stock" to the clutch pack, thus setting the driveline closer to a 50/50 split faster. "Race" should be more of the same.
    There is also a question as to whether or not GenII HPP "race" mode acts as the GenI Orange HPP, which stays locked even under braking. When I get my car back next month, the switch should be installed. I'll do vag-com logs of the controller to see if that's the case or not.
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
    Jun 2007
    240
    I haven't quite worked this out but I'm sure others have said the Haldex can only apply power to rear when the fronts start to spin ( as it works of difference in driveshaft speeds or something ). It's only meant to take a 1/4 turn more for a front wheel than back before it starts working but the fronts still need to be turning faster than the rears to engage the clutch pack.
    If this is the case what difference would the controller make? It still cannot provide power until the fronts start to spin, which probably wouldn't happen in the dry.
    Could be totally wrong on this, if somebody could explain how the system works I'd be grateful!
    ____________
    Sprint Blue S3
    boggysv's Avatar
    Nov 2007
    572
    Quote Originally Posted by s3mike
    less than quarter turn needed, just 15degrees is enough.
    read this site for more info how the haldex controller applies power to the rear more aggresively (though the pictures show a gen1, it's concept is similar)
    http://www.wak-tt.com/mods/haldexpp/haldexpp.htm
    slow-mo video of a r32 launching
    http://s113.photobucket.com/albums/n...turbo-slow.flv
    JohnS3's Avatar
    Oct 2004
    3,021
    Ouch, paintwork!!
    Aug 2005
    West London
    850
    It doesnt quite work like you have mentioned. The system will be working and transfering power all the time the car is moving fwd with some throttle input. Slip isnt wheel spin it is a difference in torque sensed between the front and rear diffs(in effect). The wheel degrees you see quoted about is the amount of front axle rotation needed from a standstill for the haldex clutch pack to be transfering maximum power aft, not for it to start transfering at all times(im not sure on how many degrees the gen 2 system needs though). There is a slight pause before it works from standstill before it transfers power as it needs the input shaft to build up pressure to close the clutch pack. Gen 2 pre-x eleminates this with the use of an electric pump to always supply pressure but thats only used by vovlo at the moment.. The pressure is always there if the car is moving and then its up to the Haldex ECU how much it closes the clutch pack to vary the power aft. With less being sent aft while high speed driving but more with agressive driving, cornering and parking.
    The HPP will send a larger amount of power aft alot more of the time to give the car more of a RWD feel compared to standard.
    Hope that helps somewhat .
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    R8GGA
    Aug 2007
    Fulham
    453
    Quote Originally Posted by Dandle
    But the thing to remember is that because of the way the gearing is connected to the front axle, no more than 50% of the power can ever go to the rear axle, so you'll never get a true RWD experience...right Dandle?
    awesome cars; both gone now though
    2004 Audi A3 3.2 Quattro S-Line DSG inAvus Silver, RNS-E Sat Nav, GSM, 18" RS4's, Bose, Tints
    2008 S3 3Dr, GIAC HAMMER, Phantom Black, RNS-E Sat Nav, GSM, FBMFSW, Optics, Privacy, Ipod, Rear Sensors, Armrest
    Weekend / Summer:
    2002 Ferrari 360 Modena, Nurburgring Silver, Bordeaux leather
    2006 BMW M6
    Nov 2007
    310
    That post by Dandle explains a lot and makes total sense.
    I guess (now I know) its obvious really as otherwise it would be purely front wheel drive for 99.99% of the time apart from when setting off violently or understeering badly round a bend under excessive power.
    Aug 2005
    West London
    850
    Quote Originally Posted by magnus911
    Thats correct the haldex unit can only move power from the front diff aft. It can be 100% rear drive but only if the front wheels are in the air or on ice etc. It will nearly always be front biased though like you say.
    Jul 2006
    160
    So is it going to handle in the dry like it does in the wet with the upgraded?
    Aug 2005
    West London
    850
    I would think it would be alot more agressive all the time. I have never driven a HPP equiped car but people who have it rave about how much better it is all the time.
    Jun 2007
    240
    Your description makes a lot more sense.. thanks Dandle.
    I was kind of wondering how it would work if power could only go to the rear when wheels are spinning. If that was the case accelerating from a standstill through puddles would mean you keep getting small doses of wheelspin as the front wheels lose grip, which I'm glad to say isn't the case.
    Once moving I never get any wheelspin, sometimes you feel a small scrabble from the front wheels when driving off in the wet but as soon as the Haldex kicks in it stops. Only problem is the ASR kicks in a bit too much and brakes / cuts power, if you turn it off the car just spins all 4 wheels for a second and then takes off.
    I keep forgetting it's 4wd but then I remember what my Leon Cupra R was like in the wet!!
    ____________
    Sprint Blue S3
