Monster MotorsportEM Tuning
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Exclamation Front windows stuck shut - Intermittent
    I've had the car in the dealers this week for an unrelated problem (engine kept stalling). It turned out to be a bad earth.
    Since I've had the car back, on a couple of occasions, the front 2 windows have refused to come down when the switch has been pressed. You can here a very slight movement but then nothing. Both times I was at the multistorey car park barrier and had to pull forward and open the door. The windows then worked OK when I pulled away!
    Seems a strange one, but would anyone have an idea whats up?
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Nov 2007
    83
    Try a 'window reset'. With the engine running pull the button as though closing the window and keep it pressed for 3 or 4 seconds.
    My one shot function to open and close the windows sometimes fails if the window sticks when moving. A reset sorts it.
    07 2.0TDi (170) SE DSG Sportback.
    Lava Grey (when it's clean!)
    5 spoke 17 inch alloys upgrade
    Reversing sensors
    No smoking pack
    Warranty issues to date:
    New steering rack - 8,000 miles
    Slight coolant loss - 12,000 miles
    New drive shafts and engine mounts - 18,500 miles
    New mechatronic unit for DSG box and replacement ducting for cooling system 19,900 miles
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    iv also encountered a problem with the drivers side window. only intermitently, when i press to open it, it goes the whole way down, then refuses to go back up when pressed to go up.
    after around 30 sec to min, it starts responding again. luckily it hasnt happened when its raining but im dreading it. thanks for the tip about resetting i shall investigate further
    i was going to visit the dealer but as its intermittent, these types of problems can turn out to be a real pain
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Thanks daveyjp, I'll give that a go
    Julian
    Previous
    2008 Red S3
