EM TuningAH Fabrications
Results 1 to 32 of 32
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    OIL change in audi A3 2006 2.0 TDI
    I have just purchased some Castrol Edge 5W-30 , VW 507 Spec.... i checked my oil dip today and it seemed half way between full and empty, should i just pour in the new oil as required or should i drain the old stuff out of the system first????
    Many Thanks
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Chuck it in.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Sep 2006
    Surrey
    1,224
    When filling up with Oil, is it wise to fill it up after it's warmed up? Does the engine need to be running?
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    hi mate
    never fill the engine while running.
    Sep 2006
    Surrey
    1,224
    Phew! I got the oil low indicator on my DIS earlier and had a little oil left at the back so filled her up but switched off the engine. It was hot though, quite abit of steam coming out. Was quite worried...
    But I won't forget that, thanks.
    You know I really should read the manual again. Just didn't think it'd tell me stuff like that ("don't re-fill engine with oil while engine is running")
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    your very lucky, it wasnt under pressure it could have blow out of the engine as u unscrewed the lid, and oil burns arent very pleasent infact they are very serious. always allow the engine to cool down or a while befor filling up the oil. i wuld say atleast give it around 20 - 30 mins after you stopped before you fill.
    Oct 2007
    166
    you may know this but for anyone who doesnt dont try to check your oil if you have just used the car as the oil will still be circulating around the engine. takes a couple of hours for it to return.
    so the stick will show nothing!!!!!
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by kettle
    Eh?
    You must have a funny car mate.
    The dipstick will show nothing until a few hours after the car has stopped?
    What nonsense.
    Aug 2007
    446
    I've always checked mine cold after the car has stood overnight in the garage. I think this gives a more reliable comparison from check to check.
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
    Aug 2007
    446
    When you check the stick just after the car stops reading the level is even more difficult as oil is dripping down from every direction and splashing the stick.
    Oct 2007
    166
    seriously try it!
    if you have just used the car it will show hardly anything.
    like twizzler said it is best to leave it overnight
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I'm sure you might get an erroneous reading THE SECOND you switch off the engine, but to suggest the dipstick will show nothing is wrong, and to suggest you need to leave it for hours is also wrong.
    If you want to be anal about it, you carry on leaving it overnight for your precious accurate reading.
    But it's a bit of a laugh really, given the dipstick itself is about as accurate as a Moldovian train timetable.
    There are huge tolerances 'built-in'.
    It seriously won't matter if you go a wee bit off, just because you didn't have time to leave it for hours....
    You'll be recommending we spirit-level the ground next, just to make sure.
    Oct 2007
    166
    i love being anal
    it takes awhile for the oil to settle
    Sep 2006
    383
    ok lets be anal here
    Make sure car is parked on a reasonable level surface
    Run the engine for a few minutes to allow oil to circulate (If left overnight all the oil that is normally dispersed in engine will have returned to the sump) Turn off engine
    Remove dipstic wipe off any oil with a rag etc
    Insert dipstic into hole fully
    Remove and check
    If level on max mark,no action req
    If on min mark top up with oil (info in handbook on quantity req between min/max mark)
    Put oil in
    Put oil filler cap back on
    Run engine again for a few mins
    Turn engine off
    Recheck level again
    PS I need to blow my tyres up do I need to remove old air in tyres first?
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Quote Originally Posted by dipstic
    You could but I'd take the tyres off and wash the inside of the tyre just to make sure there is no old air in there. Better to be on the safe side.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Sep 2006
    383
    Quote Originally Posted by marms
    OK will do,is there any special cleaner I need to remove the stuck on old air,guess its a trip to the main dealers then?
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    My oil routine goes like this.
    Wait for oil warning light to come on..AGAIN.
    Chuck 1 litre in.
    Wait another 1500 miles for oil light to come on.....AGAIN....
    It's quite easy really, I should thank Audi for giving my engine piston rings made of cheese.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Quote Originally Posted by bowfer
    Chuck 1 litre in.
    My brothers 320M Sport uses more oil than my A3 !!
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    My wife's Clio doesn't use a drop !!
    Your point is?
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    My point is that I am sick and tired of every other post you make seems to in some way slag off the Audi. I'm sure everyone here knows you do not like your A3 but I thought you might like to know that your impending purchase of a BMW may not quite live up to you're exceedingly high expectations.
    It appears as though a great number of post you make have an undertone of being very unfriendly and indeed often hostile.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Dry your eyes man, it's a thread about oil and I mentioned mine uses a lot.
    Got to laugh at your "high expectations" comment though!
    Yeah, what a dreamer I am, eh?
    Fancy expecting a car not to use a litre of oil every 1500 miles!
    What on earth am I on?!?
    LOL!
    Oct 2007
    166
    as i haven had my a3 2.0tdi long
    how much oil roughly does it use? do the majority have to fill up every 1500 miles? i do motorway miles every day as well
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Mine currently uses approx 1/2 litre every 1500 miles.
    I have notice that it uses less and less as the miles creep up.
    Oct 2007
    166
    i deffinately need to check my oil tonight then!
    done a fare few thousand miles
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    i just wanted to say...i love my audi, i just dusted a 57-volvo LOL what a fool he was, humiliating himself like that , lol
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by fesss_84
    Those artic drivers, eh?
  28. #27
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    o yer, i gave him about 20 - 30 metres head start loool the women in the passenger was gob smached LOOL if i wasnt driving id have taken a picture of them both as i flew by
  29. #28
    lucianobacheta's Avatar
    Aug 2007
    19
    same approach as bowfer here, i know it may be wrong and lazy but i wait for the low warning light to come on too. mine come on for the first time yesterday at 6700 miles, which i still think is quite bad, our 535d and even porsche 997 dont use oil that fast or even the c220 cdi i had previously. it will make sense for people that have a few of these engines to buy a drum of this oil lol! another thing that bowfer has pointed out about the tyre pressures, i thought there was something wrong with the car, till i checked the pressures, which had only dropped a pound!! lets just call that a responsive chassis.....much more responsive than an f3 car which doesnt even react much to 1psi pressure drop/rise. i could go on, the steerings a bit wierd when the power assistance cant keep up, and the ride is a bit bouncy, (rebound is a joke), but i still love the car, it chews up miles and with quattro its effortless when covering ground quickly. fuel consumption is getting better despite the weather getting colder.i like it.
  30. #29
    Jan 2007
    Hampshire
    1,155
    Excellent.
    A6 3.0 TDI.
  31. #30
    Sep 2006
    Surrey
    1,224
    Little rant: Just went to 3 petrol stations (2 BP & 1 Shell) to find me some Castrol Edge 5w-30 and all they seem to have is 0w-40! Arghhhh! Damnit why don't they stock 5w-30, is it that uncommon
  32. #31
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Shell do their own 506.01 and 507 compliant oils. I've seen them at my local station. Just use those...
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
  33. #32
    Sep 2006
    Surrey
    1,224
    Got 1litre Castro Edge from Halfords & filled it up. Got the Sonex Clear View screenwash and filled up that too.Now I don't start the car with 2 DIS alerts. Even more annoying when I had 3!!! (Diesel) lol.
