EM TuningBadger5
Results 1 to 15 of 15
    JohnS3's Avatar
    Oct 2004
    3,021
    RNSe retrofit in 2007 A3/S3 ZF short to earth
    Probably only relevant to anyone who has done this.
    Those clever chaps over at audi4ever.at have worked out a fix for the ZF short to earth issue that doesn't require re-wiring the antenna system in the tailgate. Link
    The two HF feeds from the antenna system connect to a golf/passat diversity converter and then onto the RNSe as a HF/ZF connection. The chap has posted a schematic for the connector cables too if you want to have them made up by an Austrian company called Krenn.
    I've costed some of the parts from a VW dealer -
    Golf/Passat diversity adaptor 1T0035530 - 108.61
    Power connector for the above 1C0 973 119 - 1.49
    This is a picture of the diversity adaptor mounted on its carried plate
    I've asked vagparts for a price on the adaptor, if's it's significantly cheaper than VW I'll buy one and see how I get on with it. I'll post back any results if I actually get around to it.
    If anyone can translate the page better than bablefish feel free to to do so.
    From what I can make out, the ZF issue is fixed and the reception is much better too.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    John
    What is the ZF issue as iv'e not really noticed anything wrong on mine apart from the obvious vagcom error on the radio part?
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Dec 2006
    Ireland
    2,538
    I have this same error on my rns-e (fitted two weeks ago).
    I presume this is what causes the radio reception to be very poor for stations that worked fine on the symphony II+
    Apr 2007
    142
    Thanks for posting this JohnS3 Was hoping there would be a fix for this, as i'm looking to retro-fit the RNS-E sometime next year
    MK1 Leon Cupra R: K04 Hybrid / AEM WMI / Wellycooler / Mocal Oil Cooler / Superpro Polybushed / Vibratech Mounts / KW V3's / Factory Recaros / 330bhp...
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by JamS3
    John
    Marc hit the nail on the head, it causes poor reception.
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by mitch78
    Finally! Good find John, I'll try get it done before it has to go in for a service (sometime in the next few weeks).
    Cheers.
    Good news Lee, do you know someone who can make up the required cables locally? If so I could do with a set too.
    Dec 2006
    Ireland
    2,538
    JohnS3 has posted this on navplus - seems to explain the cause of the problem.
    Thought I'd post it here, rather than having to trawl through the german site to get the gist of it.
    The symphony 2+ (shown on the left) has two HF inputs, one from the left aerial module - R108 (HF1 on pin 2) and another from aerial amplifier -R24 (HF2 on pin 3).
    The RNS-e is expecting one HF input from the left aerial module - R108 (HF on pin 5) and has one ZF output back to the left aerial module - R108 (ZF on pin 4)
    JohnS3's Avatar
    Oct 2004
    3,021
    Oh yeah, so I did!
    JohnS3's Avatar
    Oct 2004
    3,021
    Part costs from vagparts -
    1T0035530 77.81+vat
    1C0973119B 1.19+vat
    Dec 2006
    Ireland
    2,538
    would it be cheaper to just buy the sharkfin fm\am & GPS antenna?
    JohnS3's Avatar
    Oct 2004
    3,021
    Good plan, but you'd then have a ZF open circuit error showing on vagcom and the dealer VAS system. I did read that the sharkfin FM reception wasn't too good, I'll have a search for the link. Has anyone done this?
    Dec 2006
    Ireland
    2,538
    surely not, because the sharkfin is designed to work with the RNS-E, so would have the necessary ZF circuit on it.
    JohnS3's Avatar
    Oct 2004
    3,021
    As far as I'm aware the fin isn't powered and would only provide the GPS signal to the RNSe. Still looking for that link.....
    EDIT and of course an FM signal. Doh!!
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Is there a link on what to rewire in the rear to make the error go away?
