EM TuningVolks Autos
Results 1 to 10 of 10
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    Exclamation A3 Modification - HELP
    hi ppl
    I have recently bought an Audi A3 but it doesnt have an on-board computer, telling me how many MPG im doing and so on....
    Does anyone know if its possible to install this once i have the requird component, basically is the wiring already in place behind the speedometer etc etc. or would this mean i have to strip the entire car to get the wiring in?????
    many thanks in advance
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
    Dec 2006
    Ireland
    2,538
    Funny you should ask...
    I was looking around for things to do with my VAGCOM lead and came across the following:
    http://www.audiforums.com/m_336432/tm.htm
    There's no pictures, but it looks fairly straight-forward to understand.
    Here's another link from a dude who did it with a photo, but no info: http://www.tyresmoke.net/ubbthreads/.../761209/page/0
    You'll need to ground the windscreen washer level sensor:
    http://www.navplus.us/forum/viewtopi...+ground&t=1962
    Some info on the VAG coding necessary:
    http://www.tyresmoke.net/ubbthreads/...35/page/0/vc/1
    It seems all you need to buy is the multi-function wiper stalk and a repair cable for grounding the washer fluid sensor - and have access to a VAGCOM lead.
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    Thank you for that.
    audi forums link (http://www.audiforums.com/m_336432/tm.htm), within the requirements the car must be DSG unfortunately i have Manual, so its not possible to add DIS?
    cheers
    Dec 2006
    Ireland
    2,538
    just spotted the DSG reference.
    I assume there that having DGS gets you the full DIS screen even though it is not enabled.
    The manual cars without DIS presumably have only the half height DIS screen - both my A3s have had DIS so I can't comment on that.
    Looks as if it is not possible - unless you can find a instrument cluster in a breakers yard maybe?
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    this is totally unbelievable, and complicated, it not as easy as i first assumed.
    what suprises me is my peugeot came standard with a computer DIS, and and the Audi doesnt
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    i cant understand why you cant install it into a MT
    Dec 2006
    Ireland
    2,538
    I think the DSG models get the full DIS display (even if the trip computers are disabled) because the basic DIS doesn't have the piece at the bottom to display the gear selection information.
    I think the limitation on installing it in the MT cars is that they only have the basic display as they don't need to display the gear selection information.
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    so on a MT only half of the screen is ever used? does it not display graphical pics of car such as open doors.? mpg? washer fluid level? journey info? MPG? remaining fuel information?
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    i ask because, the courtesy car i have ben given is a 2.0TD VW Jetta 57-plate, and its on-board computer is excellent!!! AND its MT
    im suprised they arent found in audi A3 2.0TDI SE 2006 MT.
    simply because its only available in DSG models!
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    BTW if anyone else has any modification questions or solutions, please feel freee to post!!!!!!!!!!!!!!!!!!!
