Mine was £50 as a factory option. I can't see the price from the parts department being much different, but you never know!! You could try vagparts, they may be able to source it cheaper.
Not sure if its the same part number for both FWD and 4WD but I have the carpet load liner mentioned above from my 2wd A3 and also the flexible load liner - they both fit fine the only minor issue being the 'lashing points' are not as accessible in the Quattro with them in place due to the raised boot floor.
Both good options for keeping the boot clean and tidy.
