AH FabricationsChris Nott
    Nov 2007
    retro fit multi function steering wheel a3
    hi can anyone give me some info re what is required to marryup a multi function steering wheel and the concert head unit on my 2006 a3 if this possibe at all
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Have a look at the topic named "multi function flat bottom wheel for the S3" below on the main menu thread list.
    Basically it can be done at a cost but the multi functions on the wheel might not work if you don't have a wiring loom already fitted to your car which you probably wont as the option was not specced from the factory.
    You may be able to make a loom but I'm not aware of anyone doing this yet...
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Jan 2007
    Hampshire
    1,155
    No wiring loom required for MFSW upgrade, the signals for the function buttons are sent through the CAN.
    A6 3.0 TDI.
