JMB RetrofitsBadger5
Results 1 to 29 of 29
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    Problems putting fuel in!!!
    my car does that whole petrol pump handle click thing to signal that the tanks has reachd full capacit even when its almost empty! i have to hold the handle very light to get petrol in at a very slow rate otherwise it 'clicks' and stops
    was told the problem is probably to do with the 'ball' inside the tank which acts as a sensor, its either stuck or constantly floating on top of the fuel
    anyone experienced any problems with this? how do i go about fixing this?
    thanks
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
    Oct 2007
    166
    i have the exact same problem it caused me to over fill the tank the other night!!!
    i would be interested to find out what the problem is as well
    Dec 2006
    Ireland
    2,538
    had this problem with my first A3 until I got used to it - then when I picked up my new one in January I had the exact same problem on the first few fills. I've heard some people asking about it a couple of times at the dealer's only to be told there is no problem with it.
    I've found holding it at about 7 o'clock and not inserting the nozzle all the way in - maybe an inch shy - does the trick. (insert your own jokes here!)
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    I sometimes get this one my S3 8L. But I think its either the fuel pump youre using or you just need to push it in the right way. When it starts to happen I either just move it in and out to relocate it and if that doesn't work then I blame it on the pump it self because some pumps ALWAYS mess up.
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by Defratos
    lol
    That sounds so wrong
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    Quote Originally Posted by MarcQuinlivan
    this is exactly what im finding myself doing after a little experimentation! and even still i cannot pull the lever thing all the way back otherwise 'click', if it really isnt a problem then i guess i'll just have to plan/schedual when to put petrol in if it will take that long.....
    i am neither getting this sometimes OR only on my first few fills, its happening EVERY SINGLE TIME!!!
    DID have...
    most extras.....
    NOW have...
    Big 19's
    Dec 2006
    Ireland
    2,538
    I was getting it the first few times, but now I've found the correct angle I can just stick it in, press the lever all the way until it clicks, then squeeze in about an extra 3 litres before it is full.
    Oct 2007
    166
    i actually drove to three different stations one night because i thought it was the pump, then by the third pump i realised i was most probably my car
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    My VR6 did exactly the same its just fuel offering resistance telling the gun its full,I never did try the seven 'o'clock method....I'm thick so I just spent more time at the pumps
    Sep 2007
    10
    I get same problem. Solution - put less of the nozzle into the fuel tank pipe. I now probably only put it in half way so the end of the nozzle touches the pipe and then it's fine.
    Hope that helps everyone.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Someone once explained this to me that the pump in the petrol station is pumping too much fuel through it so it foams in the filler neck and causes it to lock off.
    I always have problems with my 8L S3 and Shell pumps, but no issue with Tescos except for one where they recently put in some new pumps which seem to be very high pressure.
    To cure either I hold the lever at half position, reducing the flow through the pump, or I turn the nozzle through 180 degrees so it is upside down and that does the trick. Just need to keep an eye on it as it will overfill and shoot out all over the floor!
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Aug 2007
    437
    Am I right in thinking this problem only affects petrol cars? My diesel fills without trouble but the pumps diesel nozzle is larger than the petrol nozzle so presumably the flow velocity is lower.
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    it is sometimes caused by the way you hold the pump whilst fillig...only a thought
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by Twizzler
    No problems filling my diesel either, even when the tank is empty.
    In fact, the local garage still lets you lock the pump on too, so you can go in and pay while the car fills itself.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Oct 2007
    166
    my car is a diesel and i have the same problem filling up!!
    I thing it depends on the pump. I use diesel and have no problems at either of the two Shell garages I normally use. I have had the occasional problem at some other garages where the pump just keeps shutting off. I find I can normally cure it by changing the angle of the nozzle or by taking the nozzle out a little.
    Dave R (h5djr)
    Aug 2007
    437
    I find the nozzle meets resistance about halfway in. I push harder and it goes right in. You can fuel it as fast as you like then. Does the filler have an anti-syphon valve? That may be the problem.
    Jul 2007
    130
    Quote Originally Posted by bowfer
    In Germany the fuel trigger locks are still used, unlike in UK where we can't be trusted for some reason. There is a way round this though - stick the fuel filler cap into the trigger guard to hold the trigger on; the auto-cutoff will still function.
    mrmuscle's Avatar
    Audi, the next best thing to Bodybuilding
    Oct 2007
    Muscle Beach, Cali
    10
    been having this problem too so i went to the shell garage yesterday for a little bit more experimentation, picked up the vpower and proceeded, i think i found the trick!
    i just about put the nozzle in pointing more upward and a little clockwise than anything and very much sticking out, this way i was able to hold the lever ALL the way down and pump away (imagine what someone who didnt know what we were talking about would think)
    thing is though, i wouldnt know when its full until i get some very expensive fluid shooting back out at me causing mess! so i can never 100% fill it up, only like high 90%'s if that makes sense
    guess its better than nothing though
    The Man With Muscles
    Oct 2007
    166
    i tried the whole angle the nozzle thing and it worked
    took two minutes instead of twenty!!!!
    Teejay's Avatar
    Mellow Yellow
    Jul 2007
    303
    I have the same issue in my TDi. Some pumps are worse than others, but all are a pain.
    I've found 5o'clock (with hand against the filler flap) and 12o'clock (yes upside down) are the best.
    I found out the later one when I couldn't be bothered to wait for a pump on the right side and was stretching the one over the roof from the other side.
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    to correct the same problem on mine I have to turn the nozzle completely upside down and it works perfectly.
    No problems anymore.
    Audi A3 2.0 TDi Sport: Lava Grey
    • Bose Symphony II Sound System
    • Integral 6 CD Changer
    • Half Leather/Alcantara
    • Light package (Great!)
    • Parking Sensors
    • Eibach Sport Springs
    • OEM Sport Exhaust Tips
    • S-Line Spoiler
    • Genuine S-Line 18" Alloys
    • "OEM Style" Dension Ipod Dock
    FOR SALE
    NEW - BOXED - GENUINE - A3 HEADLIGHTS
    80 (the pair)
    consilio's Avatar
    Up the owls!
    Aug 2007
    Northamptonshire
    659
    Quote Originally Posted by Teejay
    Innuendo bingo anyone? This thread could keep Scott Mills in material for a month!
    March 2011 - B8 Audi S4, Ibis White, S-Tronic, Leather / Alcantera Super Sports Seats, Heated Front Seats, Advanced Key, Tech Pack High, Electrically folding and auto dimming mirrors
    SOLD - 8P Audi S3. Brilliant Black, FBMF wheel, Bose, RNS-E, Auto lights/wipers, Cruise control, Tyre pressure monitor, Parking sensors, Interior light pack, GSM phone prep, Armrest, Privacy glass, Electrically folding mirrors.
    Teejay's Avatar
    Mellow Yellow
    Jul 2007
    303
    you wish yours would reach over the roof I bet!!!
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    Talking
    i only use shell fuel in my car, and iv never had the problem, by the sounds of it i think u need to insert the fuel pipe jus slightly past the "shutter" of the pipe which stops the fuel comming back out of the tank. it usually starts clicking in the pump when it gets a back-log of fuel up the pipe and the presssure builds up above a pre-determined value (which i dont knw, as i dont own a petrol station), i encountered the problem with my peugeot the first few times i filled it, this seemed to solve the probem.
    also im sure when this happenes you will be getting charged for fuel which hasnt been properly transfered into the car, causing you to pay twice for the same bit of fuel, which makes it a very expensive problem
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
    Nov 2007
    20
    tilt the nozzle slightly this works every time 4 me.
  28. #27
    MatLamont's Avatar
    Sep 2007
    63
    I have the same problem....i just put the nozzle in an inch works fine then
  29. #28
    Dec 2004
    Chester
    247
    I had exactly the same problem with my 2003 A3 2.0FSI, I traded the car in for my prsent 2005 2.0TFSI car and the problem just isn't there any more at all, I think there must be a moded fuel filler neck on later cars?
    TTS, 19's,DSG,Sat Nav,phone,elec seats,bose,ex leather,and more
  30. #29
    Dec 2008
    31
    Having this exact problem on my 2004 A3 2.0 FSI and it's really doing my head in. When I first got the car I went to 4 different stations before I eventually got fuel in, putting the pump in on a daft angle, and the second time it took me about 15 minutes to get fuel in properly. I've contacted the dealer I got it off who said he had no problem with it, yet I can't get fuel in without it being a massive pain in the arse
