Chris NottBadger5
Results 1 to 12 of 12
    Dec 2006
    Ireland
    2,538
    Bluetooth Prep Question
    Quick question for those of you who either ordered the bluetooth phone prep from the factory or retro-fitted it.
    Do you need a cradle in the car in order to enable bluetooth functionality.
    I would have assumed not, however my brother is in the process of ordering a new GTI and wants to get this fitted, however the dealer is telling him that he needs to order a cradle (for an additional 250 euro) or else the bluetooth will not work - even though he won't need the cradle since he'll be using bluetooth.
    I know this is not exactly Audi related, but I thought some of you may be able to confirm it. My impression is that the dealer doesn't really know or else is just trying to screw an extra few quid out of him.
    By the way, the reason he wants to order the bluetooth factory fit is because the GTI now comes with a whip aeriel on the roof and ordering the bluetooth gets him a shark-fin instead.
    Any help greatly appreciated.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Can't see that you need the cradle to make it WORK,but isn't this a legal thing, that the phone must be in a cradle so you can press the buttons without having to physically handle it?
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Dec 2006
    Ireland
    2,538
    sure that defeats the point of having bluetooth in the first place doesn't it!!
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Not if you have the RNS-E and bluetooth!
    I have retro fitted both sat nav and bluetooth and jut keep the phone in my pocket when getting in the car. Sat nav picks the phone up and displays caller menus and phonebook on the nav screen.
    Can call people direct from nav screen without ever having to touch phone in pocket.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Aug 2007
    41
    I have GSM phone prep. A bluetooth phone will connect and is used via the MFSW controls, the cradle is not required for a bluetooth phone.
    The cradle is needed to make use of the sharkfin and to charge the phone. The problem arises with getting a cradle for a modern phone. All existing cradles are for obsolete phones.
    Paul
    ______________________________
    A3 2.0 TFSI Sportback SE S-tronic Ice Silver
    Dec 2006
    Ireland
    2,538
    He'll be ordering the car with standard radio, but installing his MFD2 navigation unit into it - so he'll be able to make use of the screen for phonebook etc.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    No need for cradle then!
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by JamS3
    just as I thought.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    I think the problem here is that you don't actually need the cradle but you can only order the bluetooth prep with either a dash mount or armrest mount from Audi (not sre about VW but may be the same).
    Therefore if you factory order bluetooth you have to have one or the other. Others, like myself, who have retrofitted the bluetooth simply install the module under the passengers seat and use only the bluetooth connection. Control of the bluetooth is then either directly from the RNSe or via the multi-function steering wheel.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Feb 2011
    14
    I have a 56 plate with a cradle , I bought an iPhone cradle as it would not pair without it.
    I would now like to get a blackberry , is there a way to pair without buying the new cradle?
    27,099
    Yeah, just do a search for the BT module with BT mate, didnt need a cradle beforehand tbh mate, should work via BT regardless of cradle as thats whole point of the wireless system.
