JMB RetrofitsBadger5
Results 1 to 12 of 12
Thread: Flat Spot 3.2
    edition's Avatar
    Nov 2007
    1,417
    Flat Spot 3.2
    Hi,
    1st poster here with a new car (new to me). I have just bought a 05 plt a3 3.2 s-line and think i might have a problem.
    It seems to have a flat spot upto about 2k as above 2k there is a noticable step up in smoothness and power.....
    Is this normal?
    Other than that im very happy!
    Dec 2006
    Norwich
    437
    I had a flat spot on mine a bit higher in the rev range (2500-3000) which I eventually found was the little plunger had come off the end of the inlet manifold...if you open the bonnet and look down towards the rad on the right of the plastic maifold you will see what i mean, its a little vacuum unit with a little plunger coming off it to the end of the manifold...Not sure how it works but I think it opens the valve in the manifold when under load?...might not be your problem but worth a look as it had fallen off on mine somehow...?
    A3 3.2 Q SPORT DSG Now...Edition 30 Golf GTI
    Dec 2006
    Norwich
    437
    Oh & welcome to AS
    edition's Avatar
    Nov 2007
    1,417
    Thanks for the help will have a look when i get time! Just dont know if thats how they are...
    Only other problem i have is that when going slowly and putting on full lock quickly i run out of assistance. Is this normal?
    Cheers!
    Dec 2006
    Norwich
    437
    If your car is still under warranty then get it to a dealer to sort...it was a common problem on the 3.2 and a new rack was the cure I think, mine was done under warranty but I still get the problem even now,although not as bad as before...if its not under warranty then I wouldnt worry, you`ll get used to it.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Might be a software issue. My Mk 4 R32 used to suffer from this, and there was an update on Vag.com, dealer again.
    And welcome.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Nov 2004
    South East
    317
    Had it on both 3.2s I have owned. It's at about 2200rpm. Most noticeable when on a light throttle and trying to drive smoothly and it buggers it up and makes you look like a learner (or is that just me?). Wasn't aware of a cure, but have had a new rack on both cars and haven't noticed any difference - actually why would it help?
    2006MY A3 Sportback, 3.2 SLine, Manual, Brilliant Red
    Savage
    Aug 2007
    68
    Read post #4 - edition quotes a steering issue. I assume this is what Wes_G was refering to, at least I hope so
    A3 2.0T FSI S-Line
    Nov 2004
    South East
    317
    Cheers - must learn to read as well as drive properly.
    Steering rack problems are frequent - can go all lumpy if you try to turn the wheel quickly at low speeds. Either that or it makes a creaking noise when turning left. New racks are supposed to cure it but I have had three. The latest one is by far the best but not perfect.
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    excuse me for not knowing but what is a 'flat spot'?
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Quote Originally Posted by killa_z
    A point during acceleration when the engine seems to lose power for an instant.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    ah, got it!
    will have to check on mine, only got it recently so im still learning it
    DID have...
    most extras.....
    NOW have...
    Big 19's
