Chris NottBadger5
Results 1 to 9 of 9
    CJP80's Avatar
    987C
    May 2007
    249
    A3/S3 Steering Assistance
    I know this has been brought up before but has anyone been able to make changes to the steering weighting/assistance on their 2007+ A3 or S3?
    I'm keen to do this if someone has found a way through VAGCOM or various other means.
    2008 987C Porsche Cayman S (299 RWHP)
    2007 987 Porsche Boxster S (295 RWHP)
    2007 Audi S3 (330PS)
    2005 Seat Leon FR TDI (195PS)
    2005 Skoda Fabia vRS (175PS)
    JohnS3's Avatar
    Oct 2004
    3,021
    It used to be done via "VAG-COM > SELECT > 44 - Steering Assist (Drivetrain) > Adaptation - 10 > Channel 001"
    Sebastian from rosstech says "I do have something that seems to work, but the information will not be published as long as it's definitive that it works."
    However the thread went quiet. I'd also like to know so I've emailed Ross Tech to see what they have to say.
    JohnS3's Avatar
    Oct 2004
    3,021
    I got a reply from RossTech, they say that the method they had discovered wasn't deemed safe for customers to use on their cars. So back to the drawing board.....
    Stockholm
    Aug 2007
    47
    Quote Originally Posted by CJP80
    Could you please define the steering weighting assistance - what does it do?
    Is it similar to BMWs "active steering" ?
    JohnS3's Avatar
    Oct 2004
    3,021
    The rack in the A3 is electrically assisted. Using VAGCOM you can change the level of assistance to give you a lighter or heavier steering feel. I believe this is only at low speeds. I'm unsure what the BMW sctive steering is, so I can't answer that bit!
    CJP80's Avatar
    987C
    May 2007
    249
    Thanks for the update matey.
    Mar 2008
    43
    Anything new on this??
    2008 A3 Sline, 2.0TDi 140, Xenons, Factory RNS-E, Bluetooth, Armrest.
    Apr 2007
    421
    A3 2.0TDI 170 Sport
    JohnS3's Avatar
    Oct 2004
    3,021
    Not really, that method doesn't work on post 07 cars.
