Badger5Chris Nott
    Oct 2007
    How do I take off the Gear Knob?
    to my Audi A3 - 2004 edition?
    Just bought a new gear knob, eager to put it on, but I cant take the current one off!
    Any ideas?
    thanks
    Shadoh
    Apr 2004
    1,139
    if you pull the leather gater out including the outer alliminium bezel you will be able to unlock it from underneath i think
    Boydie
    Lift ash tray cover
    put fingers underneath the gear surround at the top infront of the ash tray
    pull lightly and it will pop up
    then, turn the gaiter inside out so you can see the clasp that holds the knob onto the gear stick
    use a screw driver to pry open the clip and then it should be easy enough to wiggle off
    to get the gear surround off you will see when you have it totally removed that there is a plastic surround at the bottom of the leather gaitor, there are clips on the edges (4 i think) they just need wedged out and should be an easy fix
    re-fitting! you will not be able to refit the clasp that was holding the knob to the gear stick without a special tool - i recommend a small garden hose clip with a small screw on it - does the same job!
    Oct 2007
    I took off the ashtray cover but there isn't an opening to get to the gear knob area, its all closed off.
    How do i pop open the alumnium square surrounding?
    any ideas now pls?
    Boydie
    Put your fingers on the edge where the lip of the ash tray woud meet and just pull - its simple and there is a small area to hook the tips of your fingers over
