Retro fit Lights and cruise control HELP PLEASE
fin
:puke2: My local scrap yard owning friend has an almost totally stripped new shape S3 all the good bits have gone but I can savage for myself the cruse control stalk and any other bit associated with this and the xenon headlights and again any other bit associated with them.
Can anyone point me in the direction of guides to install these items
a search should tell you how to do the cruise control, you'll need vagcom though
:hi: Can anyone help on retro fitting the lights?
Thanks for that.
I can't believe it but i hope it is is as straight forward as a plug and play swap. My work computer doesn't show the pictures hopefully my home one does.
I guess the light must have a built in ecu for leveling and a built in transformer/ignition pack. Does anyone know if this is the case?
I believe the ECU is seperate. You'll also need the vehicle level sensors on the suspension and to comply with EU law you'll also have to have headlamp washers fitted.
505
I
17
imported_andersov
I
