Monster MotorsportVolks Autos
    fin
    Oct 2007
    Smile Retro fit Lights and cruise control HELP PLEASE
    My local scrap yard owning friend has an almost totally stripped new shape S3 all the good bits have gone but I can savage for myself the cruse control stalk and any other bit associated with this and the xenon headlights and again any other bit associated with them.
    Can anyone point me in the direction of guides to install these items
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    a search should tell you how to do the cruise control, you'll need vagcom though
    fin
    Oct 2007
    Can anyone help on retro fitting the lights?
    JohnS3's Avatar
    Oct 2004
    3,021
    Is this any good?
    fin
    Oct 2007
    Thanks for that.
    I can't believe it but i hope it is is as straight forward as a plug and play swap. My work computer doesn't show the pictures hopefully my home one does.
    I guess the light must have a built in ecu for leveling and a built in transformer/ignition pack. Does anyone know if this is the case?
    JohnS3's Avatar
    Oct 2004
    3,021
    I believe the ECU is seperate. You'll also need the vehicle level sensors on the suspension and to comply with EU law you'll also have to have headlamp washers fitted.
