AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    Oct 2007
    Changing my S3 in-dash CD player to a 1 DIN player?! How?!
    Hi guys!
    What is needed to change the standard S3 (2007 model) in dash cd player to a 1 DIN Pioneer DVD/Navigation unit?
    Some sort of adapter to fit it there, but what about cabling?
    Where can I get these adapters and the cover to make the 1 DIN unit fit there in the quite "large" (over 2DIN?!) space?
    Thanks really much for your help!
    Cheers,
    Petteri
    Finland
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,201
    You would need a new single din cage, new climate unit, new switches cup holder etc, Imo not worth the hassle!.
    I had the Alpine single din sat nav unit which I sold to do the RNS-E conversion, much better option and as you already have the double din dash, I would seriously consider going down this route.
    Hope that helps
    Julian
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Deffo
    Get the standard Audi RNS-E unit. Will fit like a glove and no cabling required just plug and play.
    You will need someone to code it with a laptop though but this is no problem to someone who knows what they are doing.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    or just fit a Pioneer double din unit and put the single din on ebay.
    JohnS3's Avatar
    Oct 2004
    3,021
    I'm sure someone on here with a single DIN unit might want to "swop" the required parts.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    I've got all the single DIN stuff required if you want to drop me a PM.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Oct 2007
    Hi again!
    Ok, I might then go with the double din Pioneer / RNS-E. Any idea where I could buy a RNS-E in Europe in case I go that road?
    What about iPOD integration with RNS-E? I have the std. ipod integration now with the current player and it sucks. No titles etc.. So I really would like it to support iPOD integration well too.
    Pioneer AVIC-D3 looks also really nice.. Can even play iPOD videos from it...
    Cheers,
    Petteri
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    eBAY seems to be the best place for RNS-e. Just check the sellers feedback. There are a few selling them at the moment so you have few to choose from.
    The RNS-e uses the same iPOD interface that you are currently using. And yes it is rubbish in terms of integration.
    The RNS-e does however have 2 SD card slots that you can load with MP3's and that is a much better option and is fully supported with track names etc being displayed. The RNS-e will also be much easier to fit.
    Personally I think the RNS-e is the way forward if you want to keep the OEM look but the Pioneer will probably be better if sound/iPOD integration are higher on your priorities.
