JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    Sep 2006
    Surrey
    1,224
    Petrol Cap Not Flush - It Sticks Out
    Hi. I've noticed that with my petrol cap, it seems to always stick out just a little bit. I try to ignore but when I see other A3's and there petrol caps absolutely flush with the rear, it bothers me quite alot!
    I've already tried tightening the screw but to no avail. What is the problem & cure to this?
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    It has to be adjustable. Is it proud all the way around or just the hinge or catch side?
    I know it doesn't help but mine fits perfectly flush until you press it to release the catch and then there is just enough to get your fingers under to open it.
    Sounds to me like it could be the spring loaded catch that is the problem. Can't be that difficult to change. Looks like two screws to me?
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Sep 2006
    Surrey
    1,224
    (Sorry for the late reply)
    I'm not too sure what you mean by proud all the way around but I had a look again last night and could only see one screw. When I try and tighten it, it just turns around, it doesn't really tighten...
    I'm gonna take a picture or two and put them up once:
    a) It stops raining
    b) Theres some light
    Bare with me =)
    Sep 2006
    Surrey
    1,224
    I know i've taken my time but got around to the car today, been busy at uni. Gave it a hoovering inside and just saw that bloody cap again =/
    Heres the pics:
    This is at it's "normal" state (the one where I think somethings not right)
    This is where i've pushed it in so it can stick out
    And then this is when I push it back in once it's already out
    As you can see from the last picture, it's fine so it seems like it gradually comes out. Dunno why though =/
    Here is the problem from another angle
    What me and my cousin can't get around is, why isn't there some kind of lock on the petrol cap. Isn't it dangerous that it can be freely opened and closed like that? That's another topic but as above, that's the problem. Hope it helps!
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    The petrol flap does lock,when the car locks.
    I would suggest the fact yours isn't closing flush means it doesn't.
    It shouldn't freely open in it's unlocked state either.
    It's push to open,push to close.
    Yours is just fooked !
    Petrol flap failure isn't uncommon on A3's.
    I've had it,as haveothers on here.
    Mine used to jam shut,meaning I had to lever a key between the bodywork and the flap every time I wanted to fill up.
    New fuel flap,end of problem (apart from completely wrong tyre pressure sticker inside it now...)
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Sep 2006
    Surrey
    1,224
    Ahhh so it's meant to lock. I felt like a complete tool when my cousin came over from germany in his Saab and I had no answer for why it's like that...
    Hmmm well I hope it ain't gonna cost me alot to put right =/ but think that's been made number 1 priority now. I wonder how much it'll be.
    Thanks though Bowfer
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Warranty job ?
    Your car over three years ?
    Sep 2006
    Surrey
    1,224
    53 plated unfortunately =(
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Maybe try a breaker ?
    I had a right pain getting mine replaced.
    Apparently (allegedly..) they come from the factory 'blank',so I had to wait for the bodyshop to spray it the right colour.
    Sep 2006
    Surrey
    1,224
    I see a good amount of money going into this... One other thing is though, I recently cleaned it up because there was all black muck around the petrol hole.
    I check it again and it's back with more diesel liquid there. There some kind of leak? Very worrying...
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    The only time I get diesel around the cap area is if I overfill it myself.
    Could be the cap itself isn't sealing properly ?
    Sep 2006
    Surrey
    1,224
    Na there seems to be Diesel in there no matter how many times I clean it and i'm normally very careful.
    Well i'm gonna speak to my local garage and see what they can do. Hopefully it won't cost me a bomb! I'll keep you updated with the findings.
    Thanks Bowfer.
