Badger5Sky Insurance
Results 1 to 9 of 9
    Aug 2006
    Hertfordshire
    69
    Running In New S3
    Sorry if this has been discussed before but the search doesn't bring anything up.... I have looked, honestly!
    I've just picked up my new S3 and was wondering what is the correct thing to do in terms of running the car in? The dealer told me not to bother running it in, but I'm not too convinced.
    What are people's thoughts on this?
    Feb 2007
    Sunny Poole
    91
    Modern engines are bench run, so i didn't bother just don't go mad bouncing it off the rev limiter for the first 500 miles or so and don't boot it before the engine has warmed up.
    Others will disagree.
    2007 S3 Phantom Black - All the toys!
    Jun 2007
    240
    Dealer told me the same, but in the book it says to not use full throttle / high revs for 1500km
    I didn't manage to stick to that! I've only done 700 miles but have definately used full throttle and high revs.
    I never use full throttle / high revs until the temp has reached 90 though.
    Hasn't used a drop of oil yet.
    ____________
    Sprint Blue S3
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Mixed engine speeds but dont go above 5k rpm until 800-1000miles and it should be ok.
    I did this and had no problems, I'm on 7k now and no oil consumption at all!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    S3 LTN
    I ran it in until 1000... although dealer said 500 to me when i asked.
    Let it warm up properly... No problems at all.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    My dealer did say you could not rev it too high when cold as it would not let you? I have not tried this and wont be but my dads old polo gti would not go past 5k rpm when cold. It was like a rev limiter.
    Aug 2006
    Hertfordshire
    69
    Thanks for the advice guys.
    I plan to keep this car long term so I want to make sure I treat it properly in its early days.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Running in an S3 - Quite a few posted there thoughts here.
    Running your S3 in , what u did ?
    also Running in
    Have to agree - the search is not that hot a function on here. I think it needs an option to find 'all' search keywords rather than 'any'.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    The first 1000 miles at set revs I would personally say related to older cars with less accurate egineering tolerances. That's not to say new cars don't need bedding in a little. It is critical to bed the pistons in the first few hundred miles, drive too slow i.e. lows revs, and the barrels/rings will glaze. This will cause blow by and oil consumption. Pretty much the first few hundred miles of running is the important bit setting the engine for life. I know it goes again't what manufacturers say but according to some of them a modern car needs the same running in as a mini did 20 years ago. Should be getting my new car in about a month, I will be warming up the engine and driving the car normal with occasional load/high rpm and increasing load after a few hundred miles.
