Sky InsuranceAH Fabrications
    A3ontheA3's Avatar
    Sep 2006
    Front Tyres - Excessive Wear
    hi guys
    was quite shocked to notice that both my front standard 'Pirelli Rosso-whatevers' have worn down to the cord in the centre sections. my A3 SB 140 TDI (6onthefloor) is only a year old and has done 11.5k of mostly fast 150 mile motorway trips, I do run 'Bluefin' however but don't do drag racing at the lights etc..!! I know that I should attach a photo really but can only describe the tyres as knackered, the outsides are not too bad but the centre sections show the white reinforcing and are obviously well worn though are still probably legal, both are exactly the same, incidentally the rears are 'as new'. I don't check pressures religously but probably top-up every 4-6 weeks or so.
    Should I have a word with the dealer..?? or accept that they've had it and replace..?? have been considering Goodyear Eagle F1's
    motorbikez's Avatar
    Nov 2006
    cumbria
    2,033
    I've the same problem with my P zeros 7k miles and centre sections on front wheels worn I reckon mine will be US before 10k will be putting Contis or possibly Michelins on.
    I wouldn't bother with dealer they will say just normal wear.
    2007 Sportback S Line Tdi 170 Avus,Bose,Multi function steering wheel, Electric Lumbar support,Front centre armrest,
    Storage pack,Through load system,Folding mirrors,Non smoking pack
    2009 BMW K1300S, ABS, ASC,OBC, heated grips
    Apr 2007
    144
    The thing to remember is that the miles that you have driven bear little meaning, until you undersand the driving style. If you drive like a granny it will last a lot longer, if you drive like a hooligan a lot less.
    If you are getting scrub out on the cntre of the tyre more so than the edges then you may have the tyre pressures too high
    2007 A6 Allroad 3.2 FSI Quattro - Lava Grey, sports seats, silver Headlining, Acoustic parking, armrest, multi-function steering wheel, cruise control, Xenons, , Sat nav, GSM, Audi MMI
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I'm getting around 11-12K from a set of fronts.
    So I don't think yours is excessive at all.
    I check the pressure religiously,once a week.
    Not because I'm particularly worried about wear,just that the car's handling goes to rat**** if I drop below the recommended 38F/35R.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Oct 2006
    246
    Quote Originally Posted by jasaudi
    My missus drives our A3 moist of the time on her daily motorway commute rarely going over 70mph. I check tyres pressures every fortnight.
    My original set of Conti's on the car were worn out on the centre section of the tread also at 12k. The shoulders of the tyres which normaly show the most wear weren't that bad.
    The fwd A3 diesels do seem to wear the fronts alot faster than may be expected and makes me wonder if the centre section wearing is a 'characteristic' of the car.
    6k on and my replacement Michelin PS2's seem to be wearing a hell of a lot better.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by coupe-se
    Well I don't mean to rain on your parade,but it's always the outer sections that wear on my fwd diesel.
    The pressures are always spot on,there are no tracking issues.
    I'm told it's my 'enthusiastic' cornering that does it.
    Because of the type of driving I do (mostly A/B roads),I don't think the wear is excessive.
    However,if I were only doing motorway driving and they were wearing out at the same rate,I think I might be pretty hacked off.
    Maybe you just can't get 'hard wearing' tyres for my 18" wheels,I dunno.
    Maybe they're all soft compounds.
    Remember diesel engines are heavier than petrol,so that probably goes some way towards explaining it.
    Be interesting to see if the new A4 diesels do the same,as they have moved the engine back to make the weight more central.
