There's probably one on here somewhere but I know for a fact that there's a guide to fitting the Forge unit in the A3 section over at www.audiforums.com
all you need to do is remove the drivers side wheel
and you will be able to see the turbo and the diverter valve is on the side of it and is held on by 3 bolts. took me around an hour to do as it is quite awkward to get to, you'll need a good socket set!
