JMB RetrofitsSky Insurance
Results 1 to 20 of 20
    mdre83's Avatar
    Aug 2007
    South East
    630
    Single Din to Double Din...
    Anyone know whether it's possible to convert a single din into a double din, moving the climate controls down etc...
    Oct 2006
    99
    it is and there are instructions on line and craig on here has done it, try and search and it should come up.
    it isn't too easy though and you have to trim the climate control unit as the single din version is bigger than the double din.
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Yep, I did it for the RNS-E conversion
    It is fairly easy as long as your fairly competent mechanically and can stand the sight of your A3 dash with all its guts hanging out!!
    The hardest things to do are actually swapping to the double din cage and cutting down the climate unit.
    You will need a double din cage, all the switches, card tray and facia surround, plus depending on what radio etc your putting in, you'll need associated connectors.
    I did mine one evening and it took approx 2 hrs
    Hope that helps
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by mdre83
    This is a good link to show you how to dismantle your dash.
    mdre83's Avatar
    Aug 2007
    South East
    630
    How much smaller is the double din climate control compared to the single din one?
    Is there much to cut away?
    With the facia surrounds, is it possible to get one that is exactly the same colour/texture of the original. As you've probably guessed I'm looking to fit an aftermarket HU rather than the RNS-E unit
    I've currently got an aftermarket (Single Din) HU installed, but the surround I bought is slightly a different colour/texture. To look at from a distance it's fine, however up close you can tell the difference.
    Excellent link mate, cheers
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    The double din climate control is not just a straight trim off either side, it needs a double angled cut off each side, a case of a bit at a time and trying it, I used a junior hacksaw and a small sander. I have seen the correct climate units come up on ebay though from time to time.
    I wouldn't know about the facia surrounds though as IMO the RNS-E is the best way to go to fully integrate with the dash and the DIS. It's also a great unit on it's own merits!
    Previous
    2008 Red S3
    sat1983's Avatar
    Feb 2007
    Leeds
    708
    Anyone got any pics of their sat nav retro fitting in a single din A3? Just wondered how well they fitted. Do they look factory? Has anyone dealt with S8craig? Any pics? Just curious!
    Ex 2006 A3 2.0 TDI owner
    2010 Polo GTI 6R
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    They are exactly the same as factory fit because you use all the same parts. Can't get any pictures of mine at the moment as the cars at the dealers, while I slum it in a 57 plate A6 lemans, but I can take some when I get it back.
    Previous
    2008 Red S3
    sat1983's Avatar
    Feb 2007
    Leeds
    708
    The climate control needs trimming down doesn't it though?
    2010 Polo GTI 6R
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Quote Originally Posted by sat1983
    Take a look at one I did....
    http://clipboard.servepics.com:8081/..._a3/before.jpg
    http://clipboard.servepics.com:8081/..._a3/after2.jpg
    http://clipboard.servepics.com:8081/..._a3/after5.jpg
    sat1983's Avatar
    Feb 2007
    Leeds
    708
    Cheers craig!! Does the climate control sit further back from factory?
    **edit**it does! Looks spot on!
    2010 Polo GTI 6R
    mdre83's Avatar
    Aug 2007
    South East
    630
    whats the finish like on the edges after cutting and sanding?
    Cheers for the info...
    pics are cool, cheers mate.
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Suppose it depends how good you are at doing it, mine is spot on, but then I'm used to scribing and cutting things.
    Previous
    2008 Red S3
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I use a hand plane and get a very smooth finish.
    mdre83's Avatar
    Aug 2007
    South East
    630
    Don't fancy cutting down the single din climate controls for the coversion, also don't fancy paying 450 for the double din ones.
    Anyone out there wanting to do a double to single din conversion that is willing to swap the controls?
    ...or if anyone know where I can pick them up cheaper, please let me know
    mdre83's Avatar
    Aug 2007
    South East
    630
    Anyone?
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    JohnS3's Avatar
    Oct 2004
    3,021
    eBay item number 110174056833 no bids and starting at a tenner.
    You owe me a pint!
    mdre83's Avatar
    Aug 2007
    South East
    630
    there on me mate....what a find!
    only one thing putting me off, I aint got heated seats
    what you think...?
    JohnS3's Avatar
    Oct 2004
    3,021
    Think of it this way, two extra switches are free!!
    mdre83's Avatar
    Aug 2007
    South East
    630
    To true mate, could they be used for anything else...?
