AH FabricationsEM Tuning
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    How to change oil filter on 2.0TDI?
    Having bought 5L of 507.00 spec oil and a filter from Partco for just Ł15.50, I'm going to do an "unnecessary" intermediate oil change on my 2.0 TDI.
    Surprise though was that the replacement oil filter is just an internal element and o-ring, rather than the usual complete metal cannister.
    Can someone please tell me where the oil filter housing is on the 2.0TDI engine and whether there is anything special I need to know about swapping the element before I start the job?
    Thanks.
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    Aug 2006
    72
    You need to remove the plastic engine cover to gain access to the
    filter housing on the front of engine.
    A 32mm socket is required to undo the top of the housing.just unscrew and the filter should pull off.Relace 'o' ring.
    You will have to remove the undershield to get to the sump plug.(Torx bolts)
    (8P)A3 2.0 TDI Sport-Dolphin Grey-
    1983 (DAC)Talbot Sunbeam Lotus - Weekend Toy.
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Thanks Scott. Just finished the job.....
    Can't believe I've just got 4.5litres of 507.00 longlife spec oil for just 11.75 inc vat......
    Boydie
    i didnt have a 32mm socket had to use a hammer and a big screwdriver and hit the lid from the side to loosen the filter lol worked a treat!
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Me neither....
    I used an adjustable wrench, on the flats of the 32mm moulding, vertically from above and twisted the cover open using that.
    Jul 2007
    33
    A4 2.0TDI THINKING OF DOING THE SAME,ON THE UNDER SIDE OF THE FILTER HOUSING ALSO SEE A COVER,HAVE i GOT SAME HOUSING AS THE A3
