staz1000 said:
It'd be very easy for them to just use predicted information and simulate your readings dependant on what speed your engine is doing.
I don't doubt that it's possible to read some of the sensor outputs from a socket on the car but it's not that simple. All sensors, controls and buttons connect to an interface box on our cars. On lesser cars (he he) when you press your electric window button for example, it sends electricity (normally by providing a path to earth) to the motor to open/close it. In our case the button sends a signal to the interface unit, which is controlled by the ECU, which then sends the signal to the motor as long as all requirements have been met (the doors not opening by pulling the handle when the car is locked from the outside is one example of this).
This interface system is very complex though, and the car simply wasn't designed to have those readouts displayed on the DIS, so it begs the question, have they gone for the cheaters option and just used predicted outputs?
This page states that the unit can -
- display 0-60 mph time on the MFD (dashboard) in realtime
- display 0-90 mph time on the MFD (dashboard) in realtime
- display quarter mile time on the MFD (dashboard) in realtime
- display half mile time on the MFD (dashboard) in realtime
- display 0-100 kmh time on the MFD (dashboard) in realtime*
- display 0-140 kmh time on the MFD (dashboard) in realtime*
- display 400 metre time on the MFD (dashboard) in realtime*
- display 800 metre time on the MFD (dashboard) in realtime*
- new calibrated measuring for KMH: dyno tested, even more accurate
- display two independent data feeds at a time - choose which one to show
- new approach for time measuring, now easier to use with stick shift models
- display the absolute turbo boost pressure on 2.0t engines on the MFD (dashboard) - even while driving
- change between absolute or relative boost pressure display
- change between KPA, PSI or BAR
- display the actual o2-sensor (lambda) readings on the MFD (dashboard) in realtime
- allowing to select between 2-6 comfort blinks (factory is only OFF or 3) on either indicator
- adding a special indicator or horn sequence while you are in reverse gear
- adding Brake Light Assist
- adding Mirror Park Assist (flips down the passenger side mirror so you can see the curb)
- new temporary mirror park assist disable (no need to enter the menu to disable it)
- further improved error handling
- functions can be configured through our exclusive on dash menu via the MFD
- the module can be switched off to be completely invisible to any workshop
- easy installation - takes less than 15 minutes
- new installation harness for full plug and play: no wires to cut or splice!
*) only available on models with standard units on the dash in KMH
I doubt they would make these claims and use fake data, you could easily check with the 0 to 60 time (if you pretended you were James May)
Looks like a cool tool, did someone say group buy??
