    stevehsv868's Avatar
    Unofficial Audi UK Endurance Test Driver
    Feb 2007
    Stoke-on-Trent
    100
    Rear Anti Roll bar on a A3 8P
    Hello
    Has anyone fitted a rear "ARB" on a A3 8P ???????????????
    I had 25mm front and 32mm rear ARBs on my golf and they were great,
    just wondering if anyone has fitted one, and if their are any problems, for example, will if affect the "ESP"
    before I go and purchase
    LAND ROVER DEFENDER 2.5 Td5
    EGR valve removed, DE-cat down pipe, Turbo boost pressure increased to 22 psi, Upgraded full size intercooler, Stage 3 remap, single mass flywheel conversion, with performance pressure plate and racing friction disc. 210hp 500 Nm
    The Audi A3 2.0 TDI S line DSG Has gone and forgotten
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Your ESP will flash at you a lot more often with a stiff rear arb.
    Ben.
    '05 A3 3.2 MT6 /// KW Variant III - GenII Haldex Performance Part - H&R sways - TST Stressbrace - VF-Engineering full mounts - 17lb 8x18 Neuspeed forged wheels - CG Lock - Ross Tech
    HPA FT450 turbo installed, with world's best Torsen front diff: www.peloquins.com
    Every day's a track day ;-)
