JMB RetrofitsAH Fabrications
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 85
  1. #41
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Keep up the good work
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
  3. #42
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Thanks for the encouragement!
    As these things often go, there is a new delay: HMS, who are building the custom exhaust, have run into a silly delay. I was to pick the car up next tuesday, but now it won't be before friday at the earliest :-(
    Best to have things done properly though...
    Ben.
    '05 A3 3.2 MT6 /// KW Variant III - GenII Haldex Performance Part - H&R sways - TST Stressbrace - VF-Engineering full mounts - 17lb 8x18 Neuspeed forged wheels - CG Lock - Ross Tech
    HPA FT450 turbo installed, with world's best Torsen front diff: www.peloquins.com
    Every day's a track day ;-)
  4. #43
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Is this the same 250hp lump from the MkV R32? My mate has one on order and plans to fit a turbo but couldn't find a stockist for the MkV. Anyone know where?
    8P2 S3
  5. #44
    JaminBen's Avatar
    Jan 2005
    532
    Yes, same engine as in MkV R32, 3.2L TT, and 3.2L Porsche Cayenne.
    Ben.
  6. #45
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Anyone know any UK stockists?
    8P2 S3
  7. #46
    JaminBen's Avatar
    Jan 2005
    532
    You can contact HPA in Canada directly, or go talk with Jon Watts at www.vagtech.co.uk .
    Ben.
  8. #47
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Cheers duuuude!
    8P2 S3
  9. #48
    sat1983's Avatar
    Feb 2007
    Leeds
    708
    I'm sure JaminBen won't mind me posting this awesome vid of his "RS3"
    Kicking out 400bhp +
    Brilliant fella!!
    http://s20.photobucket.com/albums/b2...AtarbyJuju.flv
    Ex 2006 A3 2.0 TDI owner
    2010 Polo GTI 6R
  10. #49
    Dec 2006
    Norwich
    437
    Any details on how the beast drives etc etc now you have it up and running Jaminben? Looks a monster bit of kit from than vid keep up the good work and let us now some more details...
    A3 3.2 Q SPORT DSG Now...Edition 30 Golf GTI
  11. #50
    JohnS3's Avatar
    Oct 2004
    3,021
    That looks quick and I think you were only playing around!!
  12. #51
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    Talking
    Feck me, I'm guessing thats 4 wheels spinning, very impressive.
  13. #52
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Nice!!!
  14. #53
    KRL
    KRL's Avatar
    Jul 2007
    523
    Blimey!
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
  15. #54
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    ive been meaning to ask how this has been getting on now that m a fella 3.2 owner myself, Ben, enlighten us!
  16. #55
    JaminBen's Avatar
    Jan 2005
    532
    Quote Originally Posted by sat1983
    Brilliant fella!!
    Wow, did you get the vid from the french Audi forum I posted it on, or...?
    Anyways, yes the car is a BEAST. It's definitely not the same car it was prior to the turbo install: it's a completely different animal...
    It was delivered to me here in southern France two weeks ago:
    The engine work stretched to rebuilding the head, as mine had 85,000 miles on it, cast iron exhaust manifold and downpipes were painted with a ceramic heat-containing paint, while the cast aluminum intake / valve cover / oil pan / gearbox were painted with a heat-dissipating paint:
    The Torsen front diff went in, and a Spec single-mass steel flywheel and ceramic clutch also - sorry no pics.
    The HMS-built exhaust is perfectly shaped and welded. Of course, it required moving the rear-mounted battery up into the trunk by two inches:
    With over 1,000 miles on the turbo, the rebuilt engine & tranny have loosened up nicely...
    Upon startup the engine settles on a perfect 600rpm idle, just as before, but the soundtrack is completely different. Think Riva motorboat, or American V-8 with a teutonic edge "blub-blub-blub-blub...". It sounds fruity and mellow, but hard too.
    Letting off in 1st, the car is every bit as tractable as before. A short shift into 2nd, then 3rd and 4th, and 2,000rpms aren't even touched. 2nd gear starts are just as feasible as before: the car is docile as ever, but there's also something else there: a raw energy, an underlying tension. Think friendly pitbull on a leash: it'll obey orders, but you can feel it just wanting to GO!
    So when the leash is let go of, well, all hell breaks loose: the car doesn't so much accelerate as it leaps out of its skin, it doesn't just move forward no, it attacks the horizon with a frightening appetite!
    When pressed, 1st gear goes by so fast the 7200rpm rev limit comes in a flash, a quick shift to 2nd pins heads steadfastly to headrests with a strain of neck muscles, 3rd keeps shoving bowels into seats but allows for more time to appreciate the 14psi of boost. 4th is more of the same, a nice blend of aceleration rate and time-in-gear, 5th and 6th need lots of road to be pressed any amount of time: reaching the revlimit in sixth has the car swallowing geography to the tune of 180 miles per hour...
    So there you go, for less than the price of trading in an two year old A3 for a new one, one can have a surprising hot-rod. A car with subdued go-anywhere exterior looks, ergonomic and well-appointed interior, room for five, and a massive great engine.
    I'll be sure to post better quality vids later.
    Cheers,
    Ben.
  17. #56
    Feb 2007
    Sunny Poole
    91
    Awesome!
    2007 S3 Phantom Black - All the toys!
  18. #57
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Excellent job !
    Can you please give more details about the torsen front diff and the sport clutch? I would like such an upgrade on my es three.
    Cheers,
    Adrian
    P.S. Don't forget about the movies
    Audi S3 2.0 TFSI quattro - Turbo-Back exhaust - Cold Air Intake - Uprated Fuel Pump - Upgraded Clutch - Upgraded Intercooler - Stage2+ Software
  19. #58
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    very poetic Ben! we NEED more vids and pics,
    im now getting an inner urge to supercharge + NOS mine (will wait/find a company who can offer this 'properly') but then again, not so soon, thats one to come, dont want to copy you and turbocharge, that was your project, i know mine wont be as fast, but my pocket isnt as deep enough either!
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
  20. #59
    Savage
    Aug 2007
    68
    Superb work. Very nice to see some decent tuning going on. Any idea how much over 400+ bhp it's pushing out?
    A3 2.0T FSI S-Line
  21. #60
    JaminBen's Avatar
    Jan 2005
    532
    Quote Originally Posted by Savage
    Here's the dyno sheet for the 400hp version, from HGP's website. This is the same kit as mine, but without the additional fuel pump and race cats. It is set at a lower boost level than mine, with slightly lower fuel pressure too:
    My kit is rated at 445hp and 580 newton-meters of torque, on standard gas. According to the installer who did a 400hp version just before my 445hp one, the difference was greater than the numbers suggested.
    Adrian, the Torsen front diff is amazing. If you have the chance, go drive a Mgane Sport (the latest version, with front Torsen diff). Or, try to find an old Honda Integra type R. Both will give you an idea of how a front Torque Biasing Differential works, pulling the nose into the turn as torque increases.
    With our Haldex awd system, the front TBD and rear-driven wheels combine to lay power down early in turns, making for very fast corner-exit speeds. It's simply amazing. Quaife sell a TBD for our "02Q" MT6 gearbox. Cost is somewhere close to 1,000, then add similar amount to have it installed. Surely it's a lot of dosh, but the impact is profound!
    As for the clutch, mine is a Spec item... Let me have a few more miles with it before I give full judgement. For now, it's OK, but not incredible...
    Hope this helps!
    Ben.
  22. #61
    JohnS3's Avatar
    Oct 2004
    3,021
    Nearly 430 ft lbs of torque, impressive!! (sorry I don't work in NM, had to convert it )
  23. #62
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Very impressive as ever Ben.
  24. #63
    CJP80's Avatar
    987C
    May 2007
    249
    Ben Is this the one?
    Audi S3 Quattro 02M 121C 4WD 6-speed front Quaife ATB differential
    Product code: QDF14R
    Catalogue Page: 67
    583.00 (Unit price exc. VAT)
    Does the S3 have a LSD up front as standard?
    2008 987C Porsche Cayman S (299 RWHP)
    2007 987 Porsche Boxster S (295 RWHP)
    2007 Audi S3 (330PS)
    2005 Seat Leon FR TDI (195PS)
    2005 Skoda Fabia vRS (175PS)
  25. #64
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Thanks Ben for your helpful info. Now i know the next mods on my S3:
    torsen front diff and Haldex Controller.
    CJP80, i'm sure that the S3 doesn't have an LSD as standard, it has an ordinary open differential. But it would be interesting to know if that diff works on the 8P S3. Ben, please enlighten us.
  26. #65
    JaminBen's Avatar
    Jan 2005
    532
    Quote Originally Posted by CJP80
    Catalogue Page: 67
    No, that is NOT the one. The actual one needed is not on their website. I ended up with two, and so I have one (brand new, never installed) just sitting at home if anyone's interested...
    The S3 has open front and rear diffs. Audi marketing cheats by saying there's an "electronic diff lock", but that is nothing more than ABS reverse: using brakes to stop a slipping wheel a.k.a. ASR.
    The Torque Biasing Differential, or TORque-SENsing (TORSEN) differential works by sending more torque to the wheel with most grip (in a turn, this is always the outside tire). By receiving more torque, the outside tire pushes the car into the turn: and so the driver can reapply power much sooner at a corner's exit.
    In high-hp high-tq applications, it's a must.
    In an S3 which has 45 less kilos on the front wheels, this would feel even better than on my porky VR6T ;-)
    Ben.
  27. #66
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    The magic question...if you don't mind, how much do you think it cost you from start to finish?
  28. #67
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Quote Originally Posted by JaminBen
    Well, i'm planning to make the next mods (torsen diff and haldex controller) after the winter is over, so if you will have it at that time i might be interested.
    I would buy it from you now, but i've just started a new business which ate up a lot of my savings, so the diff and controller will have to wait a bit.
  29. #68
    JaminBen's Avatar
    Jan 2005
    532
    Trust me, business first, always. When you jump into being your own boss, you need all the cash flow you can muster. Your car is already 120% awesome as it is... The mods will wait ;-)
    If it isn't too indiscreet, what type of business is it?
    Eeef, the total cost (suspension, brakes, wheels, motor mounts, Haldex, engine rebuild (new head), transmission rebuild and of course turbo, cost less than trading in my 2 year old A3 for a new one ;-) As I'm planning on keeping this car forever, it made "financial sense" to me...
    Ben.
  30. #69
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    I'll send you a PM
  31. #70
    JaminBen's Avatar
    Jan 2005
    532
    In any case, the Peloquin TBD (see sig below) I had installed is better than Quaife's offering, stronger and more effectively oiled.
    I'll have to do a seperate review for it, such is its profound effect on vehicle dynamics.
    Ben.
  32. #71
    JaminBen's Avatar
    Jan 2005
    532
    Quote Originally Posted by aiculedtzu
    Adrian, I've just been given some film of an RS3 / S3 encounter... I need to edit it though, as it's quite long.
    Ben.
  33. #72
    Dec 2006
    Norwich
    437
  34. #73
    Stockholm
    Aug 2007
    47
    Wouldnt it become a problem that the S3 8Ps electronic diff lock is unremovable. a.k.a you cannot turn it off by keeping the ESP button held down for 5 secs or more?
  35. #74
    JaminBen's Avatar
    Jan 2005
    532
    Quote Originally Posted by Stockholm
    It would be as much a problem as it is now. Perhaps a little less, as the Torsen diff makes for less front wheel spin.
    Pity you guys are saddled with that silly electronic device... The torsen really works wonders on my car, especially with the HPP in its most aggressive mode.
    Ben.
  36. #75
    boggysv's Avatar
    Nov 2007
    572
    I cant seem to find your post about the switch? Did you manage to get an oem look switch?
    I also cant find your review on the peloquin vs the quaife, maybe I suck at searching
    Can you futher eloborate the problems with the esp being always on, combined with the haldex controller and front lsd?
  37. #76
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Well it's been more than a month now.
    I hope you succeeded :-)
  38. #77
    CJP80's Avatar
    987C
    May 2007
    249
    aiculedtzu, 383bhp???
    What's your boost peaking at?
    What exactly is done at stage 2? I have the same mods as you.
  39. #78
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    pm sent
  40. #79
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Hi mate,
    In overboost i have around 1.5 BAR and 1.3 / 1.35 BAR constant boost pressure, but i have to use 99 RON fuel or above to get that power.
    The funny thing is that with the Wetterauer remap i had 1.8 BAR in overboost and 1.4-1.5 constant boost pressure, but less power and torque. So i guess boost isn't everything.
    And just to make it clear, i was very satisfied with the Wetterauer Remap, but Superchips made me a better one and also it is much safer for the turbo.
    P.S. Sorry Ben for the offtopic.
  41. #80
    CJP80's Avatar
    987C
    May 2007
    249
    Sorry,
    How do they extract more power with less boost?
