AH FabricationsBadger5
Results 1 to 8 of 8
    Jan 2007
    Renfrewshire
    118
    Anyone bought one of these?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...tchlink:top:uk
    I like the fact it doesnt lock the ipod sounds good?
    What's your thoughts?
    Thanks Ross
    A4 Avant 2.0tfsi S-Line Quattro 2010, Misano Red, thinking about bluefin when i have the cash
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Hmmm looks good - especially if you can control the iPod through the head unit and MFSW....
    How easy is it to get to the CD changer input on the back of a Symphony II+????
    I might have to order one if it means I can get it fitted without having to rip half the dash apart.
    Spence
    ________________________________________
    Now: 2011 A4 Avant 2.0TDi Black Edition Multitronic Aruba Blue
    Gone at 77k: 2008 A4 Saloon 2.0TDi 140 S-Line Quartz Grey
    Gone at 80k: 2007 A3 Sportback 2.0T S-Line S-Tronic Mauritius Blue
    (4 S-Tronic boxes, 3 Mechatronics Units, 2 Dual Mass flywheels, 2 sets of engine mounts)
    Gone at 32k: 2005 A3 Sportback 2.0TDi 140 S-Line DSG
    Ebony Black
    Jan 2007
    Renfrewshire
    118
    it comes with a free set of removal keys, so assuming they work o.k. then it should be a 10 minute job!
    Well hopefully
    Hector8's Avatar
    Aug 2007
    Lisbane, N. Ireland
    55
    Thats like something i have.except iv made my connector in the ash tray and when im not using my ipod the ash tray flips down to hide the connector.
    Number plate surrounds - Surrounds NI
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by OutLore
    The sym 2+ uses the quadlock connector which has 4 internal plugs, if you have no external CD changer or a non bose system installed then the CD changer plug probably isn't fitted. See the top right plug in the diagram below.
    You might have to ask the seller what the plug looks like on the end of the unit. It may come with the correct plug and simply insert this into the quadlock. But I fear you may have to make up a connecting loom.
    Regards, John.
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Quote Originally Posted by JohnS3
    Regards, John.
    Thanks... I have Bose, but no external CD changer.... Does that mean I have the connector or not?
    Spence
    Ebony Black
    JohnS3's Avatar
    Oct 2004
    3,021
    You have the connector if you have Bose, but I doubt the pins are wired. Can you pull out your head unit and post a pic of the back of the quadlock plug?
    Jan 2007
    Renfrewshire
    118
    Asked this question....
    I have a 2005 Audi A3 with a Audi concert Head unit. It doesn't have bose, cd changer or multi function steering wheel. Will this unit be compatable?
    Reply....
    Hi,
    thanks for your enquiry, yes the unit will be compatible with your system.
    kind Regards
    So ive ordered one, ill post up the results when its fitted.
