Results 1 to 18 of 18
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Excessive Oil Consumption.........
    I bought my A3 with 5800miles on the clock 9mths ago and it now has 18000 miles on it and since i have had it i have had to put 4 litres of oil into it, i am finding this quite excessive.
    Anyone have the same problem?
    Shao_khan's Avatar
    Concrete Cow Central
    250
    Mine is pretty good - its used next to none which has supprised me. VW used to have engines (the old 2l 8v) which could really get through the oil, but none of my newer cars have.
    Nothing to see here: Woofdoggy , move along please........
    Apr 2006
    571
    Quote Originally Posted by RobinA3
    That's very high.
    My 2.0T needed topping up from new after about 3000 miles with about 1/3rd of the litre of oil supplied with the car. The level hasn't budged from 'full' since, and the car is almost a year old now.
    I would get it checked out with your dealer.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    If you look at the owners manual it states 0.5L per 600 miles is the Audis perceived excessive oil consumption.
    I know, that is rediculas but that is what the manual states,
    Mine has used 3L in 14,000 miles. I still think that's too much but Audi don't! It is VERY thin oil but the TDi's do seem to have a taste for it.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Iv'e got 5.5k on mine now and it has not used a drop!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    KRL
    KRL's Avatar
    Jul 2007
    523
    Mine has used 2.5 litres in 22k miles now. The 2.0 TFSI's do seem to like thier oil from what I've read on this forum and other forums. Unfortunately I think if you take your car to the dealer they will give you the standard answer of "the oil consumption is within the specified limits for this vehicle sir"
    Check out this thread on TSN in the GTI forum:
    http://www.tyresmoke.net/ubbthreads/...2/fpart/1/vc/1
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    We've got the following VAG products in our fleet.
    Audi A3 2.0 Fsi
    Audi A3 2.0 tdi (mine)
    Audi A4 2.0T quattro
    VW Golf 140 tdi
    VW Passat 140 tdi
    VW Jetta 140 tdi
    The MD got so sick of seeing invoices for bottles of VAG oil that he sourced bulk oil from Morris lubricants.
    Says it all.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Mine must be a good un then!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I put in half the supplied bottle at 10k5. Not a drop before that though.
    8P2 S3
    Aug 2004
    Bolton
    119
    Had a similar thing with my 53 plate 2.0TDi.
    It used about 5 litres in 18k miles, but the oil consumption gradually decreased over the 45k miles and 2 1/2 years I had the car.
    The 05 plate I have now has been much better.
    I got it last June with 10k miles on the clock and have put another 17k on top of that. In 1 year I've put in 1 litre.
    It doesn't seem to be a consistent problem with any particular engine or year, just random.
    Now: A3 Sportback 2.0TDi Sport, Akoya silver, black alcantara/leather, Bose.
    Gone: A3 2.0TDi Sport, Lava Grey
    A3 (8L) 1.9TDi Sport, Silver
    Apr 2004
    1,139
    must be because you get such good mpg figures you brag about! its gotta use juice somewhere guess your car has more of an apetite for oil than petrol!
    Jul 2007
    130
    I've read elsewhere that you need to give the engines a good thrashing when run-in to bed the piston rings and bearings properly. One of the problems with modern engines tolerances and materials is that there is very little wear with fully synthetic oils- so bedding in takes ages. A more drastic answer is to change to a non-synthetic oil for a few thousand miles.
    garypaul's Avatar
    Jun 2006
    51
    My 2.0T has used one litre of oil in 12,500 miles from new. I did notice that oil consumption has eased as the mileage has increased.
    Jan 2009
    Hi guys, I have just joined the forum abd would like to say hello at the same time.
    I bought an A3 Sline 2.0tdi quattro in feb of last year(08) I seem to be getting through a litre of oil every 3500 miles. I have just topped it up to the maximum again 1.0 lire with 7500 miles on the clock.
    You you reckon there's a problem. I rarely drive the car, it's mainly driven by the wife daily on a 8-10 mile round trip.
    Tia john
    27,072
    Are there any oil droplets under car in morning?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Try not topping it to the maximum everytime.
    The TFSi's for sure will just burn it off until it settles around the mid way point - I've on my 3rd TFSi now and they've all been the same. It's possible your TDi might be similar.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Wow old post
    My oil consumption has gone down now, only used 1 litre every 8k miles or so now. Time needed for the rings to bed in properly.
    Jan 2009
    NHN no oil under the car, I did do a visual check when the low oil level light came on the first time. I put it down the factory putting the bare minimum in. I did top it up to the full mark, but this time only half way between the two. I will have to wait and see what happens. Thx for the replys guys.
