EM TuningBadger5
Results 1 to 14 of 14
    madalex's Avatar
    S3-less untill December
    Jul 2007
    457
    Black audi s3 Window tints or not ?????
    Black Window Tints done from factory or not ?
    Boydie
    i would say no - i have done the tinted thing before and looking back on it i regret it
    also i think it would look tacky on an A3 anyway
    plus, any aftermarket or tint greater than 17% forward of the b-pillar is now illegal
    madalex's Avatar
    Jul 2007
    457
    im not sure what % the factory audi window tints are but im sure they arnt an illegal %
    siu00adg's Avatar
    Jul 2007
    995
    Saw an RS4 with tints the other day, looked rubbish because the front windows were much lighter than the back.
    If you can subtly tint all windows by the same amount that would look nice, but if you go too dark you will look like a drug dealer.
    madalex's Avatar
    Jul 2007
    457
    Quote Originally Posted by siu00adg
    are factory ones to dark ??
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Boydie
    tints from factory come out at 17% tint which is the legal limit - after that from the b-pillar forward it is illegal and you can recieve fixed penalty notices and even points!
    Shao_khan's Avatar
    Concrete Cow Central
    250
    I have had the rears of mine tinted - the factory work looks much better if you fancy it done, so if you want it order it as factory.
    Nothing to see here: Woofdoggy , move along please........
    madalex's Avatar
    Jul 2007
    457
    Quote Originally Posted by Shao_khan
    can u post some pics of it please ?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    In agree it looks **** as the rears are lighter than the front. And on black it looks worse. Best get it aftermarket. That's what I plan to do. But not too dark cos, as boydie says, it's a bit tacky.
    8P2 S3
    Shao_khan's Avatar
    250
    I'll take some pics in a bit.
    The factory tints (local dealer has a S3 withFactory tints) - the glass appears to be tinted and it looks V good. With my aftermarket tints, I have found that the factory glass has a fadeout towards the edge which is small raise black dots getting thinker towards the full black outside of the window. When you have the glass tinted it is a real sod to get the film to adequately cover all these black dots without giving air bubbles and what looks like almost a grey line around the window. I am waiting for a appointment to get a fix on mine, but as Isaid in my last post i'd seriously consider factory if you want tints.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I had a Dolphin Grey 8L S3 with "privacy glass" (tints) from the factory and got pulled by VOSA, they were highly illegal only letting 32% light thorugh the front side windows. When you were in the house you could still see through the passenger window into the car and out the drivers side too!
    They slapped a prohibition on the car that came into force within 10 days, if I didn't take them off by then!
    I wouldn't go for any cause you will be well pi**ed off if you pays your money and its wasted having to remove them.
    Apparently the factory glass with no tint is just about legal as its slightly tinted glass anyway.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    MiT
    MiT's Avatar
    Work Hard, Play harder!!
    Mar 2007
    Birmingham
    269
    A3 Sportback 2.0 TDI S-Line
    Amalfi White || Comfort Pack || Audi Sound System 10 Speakers || Interior Light Pack || Elec Lumber Support || Sat Nav || Non Smoking pack
    thebears's Avatar
    Oct 2003
    85
    I'm sure my rears are slightly darker than the fronts anyway and i didn't order privacy glass.
    From the links, midnight is a good choice and on white cars looks superb!
    A3 2.0 TDI Sport - Currently Broken
