JMB RetrofitsEM Tuning
Results 1 to 25 of 25
    Sep 2006
    Surrey
    1,224
    Petrol vs Diesel @ Same BHP. Result = ?
    I didn't know how to title this thread properly but hopefully this should explain it:
    Car A (FWD): Petrol, 1.8T @ 180bhp (stock)
    Car B (FWD): Diesel, 2.0TDI @ 140bhp mapped to 180bhp (everything else is stock)
    Which is more likely to win:
    a) Off the lights.
    b) Rolling.
    Now I know a Diesel is going to have much more Torque so would this make it faster in both scenarios?
    If so, how much more BHP does Car A need, to have the equivalent performance of Car B...?
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    At a guess I'd say the diesel would be faster from a rolling start as cos of the torque. But standing start not a clue, diesel probably needs more gearchanges to say, 60. Dont really know though.
    Phil's Barber's Avatar
    Top Gear
    Aug 2006
    89
    The diesel will also be heavier. My feeling is that petrol probably quicker to 30ish then the diesel will catch up. From a rolling start, diesel every time. This is based on nothing other than experience BTW.
    A4 2.0TDI 170 S-Line. Dolphin Grey. Symphony II+, Bose, Int Light Pack, Centre Armrest, Cruise.
    Jan 2007
    Zrich
    56
    Work Done = BHP X Torque. So if you know the torque figures of both cars then you can calculate what BHP figure you need to get the same Work Done figure.
    But as identified, there are other factors which affect the real world performance. Diesel engines are heavier which might blunt performance, but might also help traction of the front wheels off the line.
    Audi A3 Sportback SP, 2006
    2.0 TDI
    KRL
    KRL's Avatar
    Jul 2007
    523
    Remember the larger power band of the petrol should be taken into account as well. The Diesel will have run out of BHP by 4-4.5k rpm where the petrol will probably go on to 6-7k rpm. Main difference this will make is less gear changes will be required on the petrol. So the petrol would probably be quicker from the standing start and (as already said) the diesel will be quicker from the rolling start.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    but if the diesel is mapped (like it says) then the powerband will be extended. still not as high as the petrol, but should pull hard to the red line.
    - Andrew
    KRL
    KRL's Avatar
    Jul 2007
    523
    Southpaw66 made an excellent comparison of the 170 TDI v 2.0TFSI a while back:
    200TFSI vs 170TDI - Power Curve Calculations Complete
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I'm in a position to compare diesel v petrol for the same(ish) bhp quite often.
    I have a 140bhp diesel sportback,my colleague has a 150bhp Fsi 3 door.
    There is next to zero difference in straightline performance.
    Honestly,nothing at all.
    That's both cars,flat out from rest down a dual carriageway that enables speeds of up to around 110mph before you have to brake for a roundabout.
    (closed,private dual carriageway,of course).
    The difference comes once you get to the twisty bits.
    Anything that involves punching out of slow speed corners from low revs and the diesel pulls out a lead that the petrol cannot make up.
    The diesel is actually the easier car to drive in the twisty road scenario too,because gear selection isn't as important.
    Of course,this is comparing a turbo car with a non-turbo car.
    If both engines were turbo'd,the diesel's torque advantage at low revs would be negated,so it would probably just be a dead heat.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Top Gear
    Aug 2006
    89
    Quote Originally Posted by bowfer
    There's one point your missing through the twisty bits though, on the edge, the diesel is far more likely to under-steer due to the extra weight over the front wheels, assuming of course both drivers have the same level of skill, throttle control, balls etc.
    Detector's Avatar
    Just waiting for the green light
    May 2007
    Midlands
    130
    I wonder how much heavier the diesel is compared to petrol, they're both alloy construction after all.
    170 S.line manual
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by Detector
    According to the Audi site a 2.0 TFSI is actually 90kg heavier than a 2.0TDI 170 (both A3 3dr).
    Just checked A4 weights and for same engines, the diesel is 25kg heavier. I think that's probably the correct weight difference.
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    so it's like having a 14 stone-ish passenger?
    - Andrew
    Detector's Avatar
    May 2007
    Midlands
    130
    A full tank of fuel or a passenger would make quite a difference, when I sprint my car I take everything out that's not needed, spare wheel, passenger seat, tool kit, empty the ashtray etc. etc.
    170 S.line manual
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I'm pretty confident that,all things being equal,a diesel with the same power/weight as a petrol will perform in a similar manner.
    If there are differences,they'll be so small as to not matter.
    The diesel will always give the better mileage at the same time though,surely ?
    So if you can get a diesel to perform the same as a petrol,but with better mileage,then why bother with a petrol ?
    It will just come down to personal preferences about noise etc.
    I remember an Autocar test of the Alpina BMW D3 (320 diesel,tuned by Alpina to 200bhp) and the bloke's summary was something along the lines of "honestly,if you can get a diesel this good,why bother with petrol".
    It's probably only a matter of time until supercars are fitted with diesel engines too.
    Apr 2007
    Staffs
    586
    Apr 2004
    1,139
    nah i think hydrogen fuel cell vehicles will kick off in the nect couple of years and that will start to kill petrol and diesel engines in cars altogether - development in diesel technology and petrol technology will slow down in favour of fuel cell technology
    Sep 2006
    Surrey
    1,224
    Hydrogen fuel cell? Think that's stretching abit there Steve
    Here's what I think:
    Petrol > evolve into the use of TSI technology
    Diesel > particle filters will be perfected. economy will continue to rise even with increases in engine size and power
    Hybrids > become more affordable but still be outnumbered in sales
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    well manufactorers are moving from larger N/A engines to smaller turbo-charged ones giving the same or increased power, more torque, with better economy and emissions, all combined with the greater control of direct injection.
    Autocar stated that VW are experimenting with hybrid petrol/diesel engines. apparently.
    - Andrew
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by BaBs
    This is why VAG's 1.4Tfsi has always puzzled me.
    It seems to be all very clever.
    It gives the power and torque of a larger engine.
    However,it still has the emissions of a larger engine too....
    Apr 2006
    571
    Aren't you thinking of the VW 1.4 TSI (twincharger) engine ?
    The recently announced 1.4 TFSI is a standard turbo engine (developed from the 2.0 TFSI) and has quite reasonable (for petrol) emissions of 154g/km.
    Apr 2004
    1,139
    Quote Originally Posted by emzino
    no not at all - they have been playing with fuel cells for years now - and now know it is the 'only' viable way of going forward. Within the next 5 years or so i reckon they will start popping up - and at this point petrol and diesel development will reduce significantly
    Aug 2004
    Aberdeenshire
    740
    And none of the character. We had a Bora V5 and it really was a lovely engine. OK, you couldn't get much more power from it but it was so flexible and had a lovely sound. You won't get that from an anonymous inline 4.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by mfspen
    It was the one with the supercharger/turbo I meant,yes.
    It's Co2 emissions aren't good at all.
    Detector's Avatar
    May 2007
    Midlands
    130
    Didn't Alan McNish drive a diesel at the LeMans 24hr quite successfuly
    The Audi R10 is a racing car prepared for sports car racing in the LMP1 class of the 24 Hours of Le Mans and other similar endurance races. The car was unveiled Tuesday, December 13, 2005 and went on to win both its maiden race at the 2006 12 Hours of Sebring and the 2006 24 Hours of Le Mans. It was the first diesel powered car to win either of those events. This is the most ambitious and the most expensive project ever undertaken by Audi Motorsport; the Audi R10 project costs Audi $15 Million a year.
    BUT THEY CAN'T CURE THE TRACTOR SOUND
    170 S.line manual
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    Quote Originally Posted by KRL
    Nice comparison, good info
    Si
    2009-Current | Porsche Boxster 2.7
    2007-2009 | Audi A3 2.0 TDI 170 S-Line
    2005-2007 | Audi A3 1.6FSI Sport
