Badger5Monster Motorsport
Results 1 to 14 of 14
    Feb 2007
    81
    what turbo on the new s3?
    hi guys just a quick question, what turbo does the new s3 use, thanks, daz
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Borg Warner K04
    Audi S3 2.0 TFSI quattro - Turbo-Back exhaust - Cold Air Intake - Uprated Fuel Pump - Upgraded Clutch - Upgraded Intercooler - Stage2+ Software
    Sep 2006
    Surrey
    1,224
    Didn't they use the K04 in the 8L S3 after 2000-2001 (when the revision kicked in)...
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Boydie
    was itnot a ko3s in the older s3's?
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    Yes, they used K04 on the 8L S3 too.
    But on the 8P S3 it's a twin scroll K04 and I don't know if it's exactly the same as the K04 on the 8L.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Quote Originally Posted by Boydie
    Think that was only used on the later 1.8T models mate the 150bhp or 180bhp models.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Quote Originally Posted by aiculedtzu
    All the press releases and reviews state it is a completely different turbo on the new S3 compared to the old.
    This is off a review:
    "The new turbocharger has a larger turbine and compression rotor than the basic unit. Its cast steel casing produced as a single piece including the manifold withstands exhaust gas temperatures of up to 1,050 degrees. The turbocharger generates a boost pressure of 1.2 bar instead of 0.9 bar on the starting version".
    So its even very different over a 2.0TFSI
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    I'm 100% sure that the 8L S3 has K04 turbo. Try to ask this question on the 8L forum section ( i know because i did :-) )
    Although i'm not sure if they are exactly the same because the K04 on the 8P is a twin scroll turbo.
    P.S. The 200 HP 2.0 TFSI has a K03 turbo that generates 0.9 bar of boost pressure.
    Apr 2007
    23
    basicallythe k03 was used in 150bhp A3/A4, 163bhp 190bhp, TT180bhp, the K04 was used in the old S3, cupa R , and TT225, the KO4 on the new S3 is the same as the old S3 but better and internals basically to move more air and quicker.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    The 8L does have a KO4 turbo, as I had 2 of them!
    I understood from my post above the 2.0TFSI also has a KO4 turbo but the S3 turbo is a revised version of this?
    Apr 2007
    23
    i have said the the old S3 has the KO4, the 2.0tfsi gti engine has the KO3, the edition 30, edition pirelli has the KO4.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I know you did but look at the times on the top left of the posts, I was typing my reply to aiculedtzu as you did yours and we posted at the same time!
    Apr 2007
    23
    my mistake sorry".
    Aug 2005
    West London
    850
    Im pretty sure that the 2.0TFSI has a new version of the K03, not sure which one though. The S3 is running a new version of the K04. I had a old pdf somewhere for the 2.0TFSI engine which showed the turbo(can't find it now though).
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
