I use itunes for all my music, mainly because it stores everything nicely and you can easily edit your info (tack #, name, album etc)
IMPORTANT! - If you are going to use itunes, go into preferences/advanced/importing, then select mp3 as the default import. If you dont do this, all your music will be downscaled to the dreaded AAC format! AAC is the default coding for apple music and wont work on anything but apple/itunes.
So in summary:
* google itunes
* downlaod latest itunes programme
* install it (makes sure u select NOT to search for music, you can do this yourself afterwards.
* do as i said above from the edit tab within itunes, and change the default converter to mp3 (NOT AAC!!!)
* then just put a CD in your PC tray, it will prompt u to import to itunes. Failing that, open itunes THEN put your CD in. The CD will pop up, then just tell it to import :icon_thumright: (if you have followed these steps you should easily get all your CDs on MP3 format and stored Nicely for you to add to your SD card.
Phew.... Did that make sense to anybody or just me
