    Dec 2004
    Portugal
    65
    Unhappy Radiator fans working sometimes
    My both radiator fans started to work whenever they want.
    Basically even with the engine still cold the fans start to work and stops after a while...it depends how much
    They seem to work in full throttle.
    Audi dealer said both fans need to be changed
    Anyone could explain your experiences with it?
    Couldn't that be a module, or faulty temp sensor?
    DaveS3Turbo's Avatar
    Sepang Blue S3
    Oct 2003
    1,062
    Hey on my 2.0T Quattro the fans wouldn't turn off even when the ignition was off. After on full whack for an hours or so the battery was flattened.
    They replaced the whole fan module / sensor etc... After it kept repeating itself..
    DM
    Let them carry out the warranty work. They take the whole front off to do this.
    2012 Porsche Cayman R Peridot Green MY12
    2011 Porsche Cayman S Basalt Black MY08
    2010 S3 Sepang Blue MY10
    2009 S3 Imola Yellow MY09
    2007 S3 Solar Orange MY08
    2005 A3 2.0T FSI Quattro S-Line 200Bhp MY06 : Misano Red
    2003 A3 2.0Tdi Sport 140Bhp MY04 : Brilliant Black
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Could it be the condensor fan for the air con maybe? I'll have a look which is which etc in a bit
    8P2 S3
    wilko's Avatar
    Top Gear
    Feb 2005
    Nottingham (UK)
    724
    Mine sound like they come on as well even when the engine is cold. Was gonna raise it next time I heard it do it - but typically I haven't heard it since. If you find out why it does this please let us no.
    A3 2.0 TDI Sport in Akoya Silver - with... Black Alcantara, Black Headlining, Aluminium Inlay's, Interior Light Pack, Storage & Luggage Pack, Front Armrest, Electronic Climate Control, Non-smoking Pack, First Aid Kit & Warning Triangle, Electric Sunroof, Heated/Folding Door Mirrors, Sony CDX-GT930UI with USB iPod Connector & BOSE, 17" '5 Spoke Star' Alloys, Light & Rain Sensors, Xenons, Vortex Rear Spoiler, GTI Aluminium Pedals & Black Brake Callipers!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Right I've finally had a look under the bonnet and I was right.
    Both the radiator cooling fans also act as the condensor fans for the air con system. They don't work at full speed for this though. They will move into full speed if the engine needs forced air.
    If you want to check if this is what you are experiencing then simply turn off your air con (press the ECON button) and after a short time (depending on how long the system has been running and the ambient air temperature) the fans will switch off. Do this when the engine is cold so the fans aren't running anyway to cool the engine.
    Also this is why the fans continue to run after switching off the engine. I'd guess they run so high pressure liquid is available in preparation for you switching the engine back on i.e. when you get back into your car and switch on the cooling will be there sooner.
    EDIT: Actually the fans stay on to change all the remaining vapour into liquid for safety.
    8P2 S3
